RV215W No 40Mhz channel?
marcovd
I installed one RV215W (fw 1.3.0.8) router in my company and after configuring it I realized that It never uses the secondary wireless channel even with 20/40 Mhz is selected in Wireless->Basic Settings-> Wireless band Selection, using WPA with AES encryption, and 802.11 only selected. Tried auto and manual channel selection also.
I tried forcing the N transmission Rate between 65/135 and 130/270 mbps with no luck, even worst because no devices can connect.
Using WiFi Analyzer in my mobile phone I can see only one channel being used.
All my devices are capable 150 Mbps / 300 Mpbs capable and successfully tested with different routers and access points from other vendors.
Any suggestions?
boatanas
Dear Customer,
The issue you have come across might require some further testing. Would be able to open up a support case with us? Here are all Small Business Support numbers: https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Thank you!
Borislav Atanassov
Cisco Small Business TAC
Funny thing is that I can't register using my corporate email because its already registered on Cisco Support Communities.
