02-24-2015 08:25 AM
Does anyone have any expertize or experience in whether to mount these small business Wireless Access Points vertically or horizontially
The mounting location is under a wood floor in a long, thin building with all the clients above the WAPs.
Thanks in advance
02-24-2015 08:32 AM
First, recommendations have always been that WAPs should be mounted high in a building rather than lower.
Second, I've mounted WAPs vertically on a wall or horizontally on a ceiling. I tend to find that ceiling mounts cover better, but coverage really is about what outside influences are there to the signal (wall construction - wood is better than metal, pipe construction - copper and iron pipes tend to really muck things up, proximity to high voltage appliances like stoves, heat pumps, etc.., proximity to microwaves - they operate on the same basic frequency as 2.4Ghz 802.11x., etc...) rather than vertical or horizontal mounting. I'm not sure how well your signal is going to deal with being below everyone, especially if there are lots of pipes or wires below the floor too.
When I'm in a building with difficult access to the ceiling I tend to find a closet where I can run cable through to the ceiling to conceal the wire and then mount it like a smoke detector. With PoE you don't have to worry about power to the unit, just the Ethernet cable so that makes it a lot easier.
Good luck.
02-24-2015 11:51 AM
Thanks Brian
All good points.
This is a temp rental so i am going for the best i can get as opposed to optimal! I can not get into the ceiling because of the tenant above but there is easy access below. However, your suggestion on finding a closet for ceiling mount is better than i had thought of.
Thanks again
