04-24-2013 12:50 AM
I'd like to filter traffic on certain ssid on wap121. I want that clients will be allowed only to access certain services, such as http, https, pop3, smtp, imap.
I have tried with setting up access list/ class map/ policy map configuration in Client QoS menu, but it seems I'm doing something wrong here.
Any help will be appreciated.
Solved! Go to Solution.
04-29-2013 08:25 AM
Hi Anze, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. Bellow you can find a link with specific steps in order to help you with your filtering configuration also the port that you want to allow also you need to create a rule denying the rest.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2211
http: 80
https: 443
Pop3: 110
SMTP: 25
imap: 143
I hope you find this answer useful
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
04-29-2013 08:25 AM
http: 80
https: 443
Pop3: 110
SMTP: 25
imap: 143
Greetings,
