Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 3061 Views
  • 1 replies
  • 5 Helpful votes
Hello,I've got a problem to set up wireless network with radius authentication.I've set up a CA and made a certificate for a user.I've set up IAS to accept connections.when i try to connect to my WIFI, it's refused :logs :Jan 3 2000 06:17:35infohosta...
waaalex66 by Level 1
  • 1534 Views
  • 1 replies
Hoperfully someone can clarify my confusion as to whether the WRVS4400N can utilise a repeater to increase it's range.This thread https://supportforums.cisco.com/thread/2065036 suggests that it is not possible, but early on it states that there is no...
Hi, I have 4 WAP321 connect to SW300-8MP, use POE, configured in cluster (single point setup) After 5-7 day all AP are HUNG ( not respond to ping, can not acces http interface)Last time it happened an AP respond to ping and http while the rest were b...
alex by Level 1
  • 1302 Views
  • 2 replies
                   hi,I've configured the 321 device, it's working fine for browsing.the problem I'm having is when I'm connected on the wired network I can watch an entire youtube video but when I'm on wifi on the 321 device the video at some point ...
Sir,Any body help me,i have Wap 4410n number of 9 Access point , we are configure and mount all of AP when i move all area  then my network was disconnected ,i have configure bellow setting without controler  are sugest me which controler i used,1)  ...
