wap121 traffic filtering
anzes_r6_
I'd like to filter traffic on certain ssid on wap121. I want that clients will be allowed only to access certain services, such as http, https, pop3, smtp, imap.
I have tried with setting up access list/ class map/ policy map configuration in Client QoS menu, but it seems I'm doing something wrong here.
Any help will be appreciated.
jonatrod
Level 7
Level 7
Hi Anze, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. Bellow you can find a link with specific steps in order to help you with your filtering configuration also the port that you want to allow also you need to create a rule denying the rest.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2211
http: 80
https: 443
Pop3: 110
SMTP: 25
imap: 143
I hope you find this answer useful
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
jonatrod
Level 7
Level 7
http: 80
https: 443
Pop3: 110
SMTP: 25
imap: 143
Greetings,
