02-21-2013 06:23 AM
Hi all,
i have a problem with the AP WAP200, i can't make access to web setup. It gives to me the error "Unauthorised" without asks to me user or pass.
I tried to reset the AP and i tried to access with others pc and smatphones but the problem persists.
Anyone can help me please?
Solved! Go to Solution.
02-24-2013 12:18 PM
The WAP200 has a default setting that blocks access to the administration pages if you are trying to use them from a wireless client. Have you tried accessing the admin page from a wired connection? Once you get in that way you can go to the Administration tab and enable the Wireless Web Access option.
Let me know if that works for you,
Christopher Ebert
Network Support Engineer
Cisco Small Business Support Center
02-21-2013 07:05 AM
Wrong forum, post in "small business - wireless". You can move your post using the actions panel on the right.
02-21-2013 02:18 PM
02-24-2013 02:17 AM
UP
02-24-2013 12:18 PM
Christopher Ebert
03-03-2013 02:00 AM
It works Thanks a lot
