WAP321 Captive Portal SA520 Inter VLAN Routing
dirproservices
I have setup a WAP321 and configured it for a captive portal. It is connected to a SG300 switch and the gateway is a SA520.
The SA520 is setup with two VLANs. The default of ID 1 and a guest vlan ID 2.
The SA520 is assigning the IP addresses to VLAN ID 2. That is working properly.And the captive portal works fine as long as I have Inter VLAN Routing Enabled on VLAN ID 2. But, I do not want VLAN ID 2 to access the local LAN so I Disabled the setting for VLAN ID 2. When I do that, the captive portal stops working and I just get a blank page. Nothing comes up. If I disable captive portal on the WAP321 with Inter VLAN Routing disabled, everything works fine. No access to VLAN ID 1 and Internet access works fine.
So, what am I missing here? I don't want wireless guests to have access to internal LAN systems.
Tom Watts
Hi Dir, the problem is, the captive resides at the IP address of the AP. If you disable intervlan routing, the vlan 2 can't talk to vlan 1 - where the CP resides. Change the AP to be in the same subnet as your guest network and this will work.
Edit-
Example;
Vlan 1 192.168.75.1
Vlan 2 192.168.76.1
AP 192.168.76.2
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Well, I changed the WAP321 to an IP address and gateway on VLAN 2 and disabled Inter VLAN routing on VLAN 2. It routes perfectly, as expected, as long as Capture Portal is not enabled. Once CP was enabled it stopped working. I can't ping anything and, of course, get webpage not available. There is something about Capture Portal that seems to be causing this problem now. In fact, I just enabled Inter VLAN routing and it still does not work in this new configuration with CP enabled.
