WAP571 no Internet Access over switch SG350
kolar52
Hallo,
I have a switch SG350 with its basic configuration, I am still building my network. In the meantime I got WAP571 which is directly connected to the switch. I did initial configuration and I can connect to access point but there is NO INTERNET ACCESS.
WAP is connected to the switch on Port 5 - Trunk - Layer 2. It is assigned to VLAN1.
DHCP on access point is enabled but the computer still doesn't get IP automatically, and I have manually set 192- address on the client to access the WAP web-interface.
Can you help and write how to configure access point to access the internet?
Setup is: Router > Switch > Access Point
Sujoy Paria
DHCP server option to provide DHCP IP to the wireless client is not available on the WAP571 device, it can get DHCP IP. So, you need a different DHCP source, either on the router or switch. It will be helpful to understand the scenario in case you can share the IP details of those devices also.
