WAP571 SLOW WIFI
HAVA
i have 3 units of wap571, since last update:
Release 1.1.0.3 WAP571_WAP571E_1.1.0.3.tar 26-Apr-2019
the wifi throughput is 20mbps on both 2.4-5ghz
i made restore to factory defaults, no vlans , just all units configured as dhcp cliants and wpa2 password
they conncted to the SG110-16HP switch and the router is the ISP's router with 1G internet fiber connection
wired lan test resaults are 600-900 mbs
also tried to use just 1 unit of wap571 and nothing else on the network with just the 5ghz on and still the wifi speed is 20mbps on all devices
Hi Hava, were you able to resolve this? I have the same problem. I have two WAP571 connected to RV260P. Both have download speed of ~20Mbps whereas the upload speed is ~170Mbps. I am running 1.1.0.3 firmware on both WAP571s.
Is there a cause/solution for this?
i tryed to get support from the local dealer and thay also fail to understand the issue or to replace them with warrenty
i  sold them as used/mulfunction and will never use WAP devices from cisco.
Thanks for your response Hava! I reset my router to factory settings, reconfigured and retried and that worked for me
