1130AG LAP to Autonomous mode
MARVIN SPITERI
I have a brand new AIR-LAP1131AG and i need to convert it to autonomous mode. I follwed the exact procedure using tftp and reboot with the mode button pressed, I keep getting that
ERROR: Failed to extract from archive file tftp://255.255.255.255/c1130-k9w7-tar.default - I have renamed the .tar file to as instructed to c1130-k9w7-tar.default and tried different versions of IOS to no avail
5 Replies 5
Rob Huffman
Hi Marvin,
Sounds like a TFTP issue. Can you double check Step 3a & 3b;
Step 3 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View > Show hidden files and folders.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Hope this helps!
Rob
hi
yes that is what i thought at first but all fine - i did couple of tftp trabsfers before all basic requirements are ok. I suspect that the problem is with the file renaming somehow.
I downloaded the latest IOS zip file c1130-k9w7-tar.124-10b.JDA extracted all in a new folder and renamed the file c1130-k9w7-mx.124-10b.JDA to c1130-k9w7-tar.default and pointed tftp folder to its root folder which was created during unzip c1130-k9w7-mx.124-10b.JDA
i am getting the following error from console :-
from tftp server log:-
09/12/2008 16:53 :Sending c1130-k9w7-tar.default to (10.0.0.1)
09/12/2008 16:53 :Timeout error sending c1130-k9w7-tar.default from (10.0.0.1), 0 bytes
Try using 3cdeamon TFTP.... seen this error when using other tftp servers.
-Scott
hi issue solved the tar file was keeping the .tar extension and this was not visible....
Many thanks for your support
