1142 and 2602 to join 3802 ME controller
bikoo106
Hello everyone,
i would like to know if it's possible for 1142 and 2602i to join 3802i ME controller,
I’m able to join the WLC using 2702i
but the 2602i and 1142 is not joining even after i update the FW for both to the latest one from Cisco.
i assigned IP and GW using capwap ap ip address command but still getting the below error
_______________________________________________________________
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)31.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.10.2 peer_port: 5246
*Oct 2 18:08:31.243: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.10.2 peer_port: 5246
*Oct 2 18:08:31.243: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.10.2
*Oct 2 18:08:31.247: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.10.10.2
*Oct 2 18:08:31.247: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.10.2:5246
the 3802 ME IP is 10.10.10.2 and there's no DHCP configured, the 2702i joined very smoothly without any problem
thanks.
marce1000
 - Check if all compatibility-parameters concerning ap-models + controller and software versions are fulfilled using the info's below :
    https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-393660
 M.
bikoo106
is anyone here can help me please
marce1000
 M.
M's answer is correct - short answer is NO, those old APs are not supported by the latest release, and haven't been for some time.
