11b client and 11g Access Point
daylight28
Can 11g Access Point support 11b client ?
i have a Access Point AIR-AP1231G-E-K9.
Users with a 11g client adaptor is able to login successfully, but users with 11b client adaptor is not able to login.
How should i configure that AP so that 11b client can login as well ?
Should i downgrade my access point back to pure 11b ?
jolmo
Level 4
Level 4
11b users should be able to log in, as this AP supports both 11b and 11g at the same time.
Please try this:
Under interface dot11Radio0, configure:
speed default.
This should set data rates to factory default settings allowing both 802.11b and 802.11g client devices to associate to the access point’s 802.11g radio.
the problem was solved after i changed the channel settings to channel 11, it was channel 12 previously on the g radio.
