03-11-2011 03:40 AM - edited 07-03-2021 07:56 PM
hello guys,
Can you tell me if i can use ANT2460P-R with a single 1242 Access Point?
And the power injector has suficcient POWER?
regards
NC
03-11-2011 04:10 AM
yes you can.
The power injector doesn't care about the antenna installed. So the normal power injector for the AP is fine.
03-11-2011 04:37 AM
Hi Nicolas,
Thank you very much.
Can you tell me what is the distance for the AIR-ANT2460P-R Antenna in clear sight?
regards,
Nuno
03-11-2011 04:43 AM
It depends on a lot of things, including who is on the other side (client ? ap ?).
I suggest using this nice calculator : http://www.cisco.com/en/US/products/hw/wireless/ps458/products_tech_note09186a008009459b.shtml
