1500 Questions
nkariyawasam
Level 6
Level 6
I am configuring point-to-multipoint outdorr W'less mesh network using 1500.
Since 1550 requires WLC ( Wireless LAn Controller ) I have configured one at central site.
Q1. Does each remote site also requires WLC at respective locations ?
Q2. Can the bridge functionality in 1500 support extending multi[pla VLAN traffic to the remote 1500 ?
sakthicisco
Level 2
Level 2
hai sam
Iam also in the same boat.i want to configure point to multipoint outdoor using 1300....
if u hav any idea about this can share with me ,so that it wud b helpful in configuring it.
can u just tell me wat is a subscriber unit?
awaiting for ur reply...
If you converted your 1300 to lwapp you lose the bridging. If your ios based try this document
http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_chapter09186a008021e5de.html
retiredmarine
Level 2
Level 2
a Mesh Access Point (MAP) can have an ethernet connection. so you don't have to have a wlc on each site.
try these documents http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1500/ap1500qs.pdf
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a008077c05d.pdf
My local MAP ( mesh Access Point ) can have WLC attached to its Ethernet port. But, how about the remote MAP ? Does it also requires another WLC connected to its Ethernet Port for the propoer operation?
