Bookmark
Subscribe
1599
1552 Mesh AP. Ethernet Port Flapping
lukedp
I am having an issue with a 1552AP that is acting as a MAP, i have a AXIS camera attached to the POE out port via a midspan (
midspan that it obtains its data from a data port and poe out port from the camera). The port comes up then appears then fails.
I tried attaching a laptop to a test ap in the lap and connects to the mesh. in this instance the ap and the device attached to the AP work.
is there any trouble shooting i can do to test the status of the AP.
1. Connect a laptop instead of the camera and see if the link still flaps.
2. Connect a console port to the AP and check its status messages when cameras are flapping. I was suspecting a power feeder issue.
8 Replies 8
Scott Fella
Is there anyway you can power up the axis camera without using the midspans just to test? I recently had some issue with using the midspans to power up some AP's because the client didn't have any PoE switches. This wasn't on a mesh ap though.
-Scott
vlad.mihailov
How is your AP getting its power?
Hi Scott / Vlad,
The AP obtains it's power from the cisco power cable that plug into the base.
The camera works when directly plugged into the wired network switch with the same midspan.
When plugged into the1552 mesh ap on the PoE Out port the GI port fails up and down.
Was a power draw issue, the Midspan althougth documented to reach 100m PoE does not. i found that at 10m the camera worked.
From you earlier post, it seemed like you tested it fine?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I have seen issues with long PoE (at the edge of the specifications) when system was used with bad Ethernet cables. Worth checking if its a proper outdoor rated cable with thick gauge.
Abhishek Abhishek
Yes, it is advisable to use laptop instead of camera . Also to connect port to AP and check the status messages.
