2.4 GHz. Frequency setting.
alikoca869453
There are 11 access points in the system. The distance between them is 80 mt. only the difference between 3 of them 450 mt. 2.4 MHz. Signals between operating devices are low. The current frequency settings are as shown in the picture. how the settings should be.
19 Replies 19
but I couldn't find the exact value
2.4 Devices have low signal. In fact the problem is simple here which value should I enter.
You should enter the correct Antenna Gain, based on the attached antenna, minus a possible cable loss (if you use extension cables).
To change/enable DCA you have to temporarily disable the 2.4 GHz network first, enable/change DCA, then enable the 2.4 GHz network again.
I also recommend that you only use the channels 1, 6 and 11 for maximum compatibility.
Could you please share a screenshot from Wireless>802.11b/g/n>Network.
I want to see data rates
Hold on ... ANT2568VG & ANT2513P4M are DUAL-BAND antennas. Are you saying you've got two of these APs connected to the same AP?????
