2 SSIDs on the same Vlan?
James Andrews
Frequent Visitor
Frequent Visitor
Hi all -
Newbie question. When I am setting up wireless, will I be able to use 2 different SSIDs on the same vlan?
Example:
dot11 ssid Example1
vlan 2
authentication open eap eap_methods
authentication network-eap eap_methods
dot11 ssid Example2
vlan 2
authentication open eap_methods
Rob Huffman
Hi James,
Hopefully the attached docs will answer your question:
Cisco Aironet 1100 Series
Using VLANs with Cisco Aironet Wireless Equipment
Deprecated versions of Cisco Aironet software permit binding multiple SSIDs to one VLAN. Current versions do not.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml#
Cisco IOS Software Configuration Guide for Cisco Aironet Access Points, 12.2(15)JA
Configuring Multiple SSIDs
vlan vlan-id
(Optional) Assign the SSID to a VLAN on your network. Client devices that associate using the SSID are grouped into this VLAN. You can assign only one SSID to a VLAN.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a00802085c4.html
Hope this helps!
Rob
Please remember to rate helpful posts.......
Rob Huffman
Hi James,
vlan vlan-id
Hope this helps!
Rob
This answered my question. Thank you Rob!
