2504 GUI not showing clients connecting at 5Ghz
dean-obrien
Hi all
Recently upgraded our infrastructure to v8.0.100.0, on the 'new' landing page, the GUI is showing no clients connecting on 5Ghz, only on 2.4Ghz.
If I check from the CLI, there are clients connected on 5Ghz.
Is anybody else seeing this?
Is it just a 'bug' (does anyone know)?
Please see attached.
Cheers
5 Replies 5
Sandeep Choudhary
HI Dean,
There is no bug.Here is the  attached screenshot from my WLC:
I see that this is the Foreign Controller.
Can you paste the info from Anchor controller:
sh client summary
Dont forget to rate helpful posts
Hi Sandeep
Attached is info from Anchor Ctrl.
Cheers
Hi Dean,
Let me test your scenario. Will give the my test result in 5 minute.
ok, cheers.
I'll await your response.
I test your scenario and showing as it should be.
MAC Address       AP Name           Slot Status        WLAN  Auth Protocol         Port Wired PMIPV6  Role
48:43:xx.xxx.c3:92 AP001           1   Associated     3    Yes  802.11a          13   No    No      Export foreign
check the screenshot:
