05-08-2015 09:18 AM - edited 07-05-2021 03:11 AM
Can I create two separate LAG groups to two different 4500 switches that are etherchanneled together? The docs on the 2500 indicate that the LAG ports must go to the same switch unless it's a 6000 in VSS mode or Nexus VPC. However, I'm just looking for essentially a cold stand by failover, not active-active. Attached are some diagrams.
Solved! Go to Solution.
05-08-2015 11:27 AM
NO, once you enable LAG, all ports of controller belong to same port group. So other end should be VSS/VPC pair if it is two different chassis
Rasika
*** Pls rate all useful responses ***
05-08-2015 11:27 AM
Rasika
05-08-2015 01:08 PM
That's what I figured. I'll set everything up and then just keep the ports on the backup chassis shut down. It won't be automatic failover, but then again wireless for us isn't mission critical.
05-10-2015 04:38 AM
Scott,
Since the 2504 is typically in smaller environments due to the AP limit and client limit, what you can look at is not using LAG, but defining a primary and secondary port. So if port 1-2 is on switch 1 and port 3-4 is on switch 2, you can setup the 2504 like this:
Management interface:
port 1 primary
port 3 backup
Dynamic interfaces for your SSID's:
port 2 primary
port 4 backup
You can define some dynamic interfaces using the same as management also, but at least you have redundancy if a chassis fails with no manual intervention.
-Scott
06-17-2015 12:14 PM
Scott -
Yup. But it's been a while since I've used dynamic interfaces and was hoping to have 2 GB throughput rather than 1 GB. I think I'll hook it all up physically the way I want it and keep the ports on the backup switch shut down. Then I'll just open them in the event of a failure.
