Universal Workgroup Bridge & IP Broadcasts
rshade-cti
Community Member
I'm attempting to configure the integrated AP in the C819 as a bridge.  I can't rely on the infrastructure to be Cisco, so I'm using "station-role workgroup-bridge universal" with the MAC of the router.  For some reason, the bridge AP is not accepting/forwarding broadcast traffic from the infrastructure.  Broadcast packets (DHCP/ARP) egress the bridge AP (I can see them on the infrastructure side), but the replies never make it through the bridge AP.  I blame the bridge AP because other clients can ARP/DHCP just fine w/the infrastructure.  Unicast packets from the infrastructure are forwarded correctly.
We currently have a few hundred 3200 MARs using this exact technique and they don't have trouble with broadcasts.
Any idea what I could be missing?
7 Replies 7
ali aqrabawi
Level 8
Level 8
with WGB and multiple vlans two things should be configured :
1) add the command "infra-structure SSID" , under the WGB SSID .
2)the WGB SSID should be in native vlan which is 12 , i see its configured for 11 and 11 is tagged vlan.
correct these two things and it should work ,
Thanks for looking at it, Ali.
Unfortunately, I'm still seeing the same behavior that suggestion.  My current config is attached.
yes the configuration now is correct ,
is it working now ?
No.  The router is still not receiving any of the broadcast packets from the wireless.
can you share the show run from the root AP ?
is it cisco or non-cisco AP ?
collect show brdige and show arp from the WGB .
and show run from 3200 mobility router
do you see the DHCP packet going out the wired/wireless clients behind the WGB , but no reply from the other side ? or you are checking from the root AP side ,
if you connect a wired client behind the bridge to vlan 20 , does it take ip address ?
Sorry for the delay.  Thanks again for looking at this.
> attached
> Cisco, for testing purposes
vehicle-router-ap#show bridge
Total of 300 station blocks, 299 free
Codes: P - permanent, S - self
Bridge Group 1:
    Address       Action   Interface       Age   RX count   TX count
6cfa.89d5.84a2   forward   Gi0.11            0          5          0
vehicle-router-ap#show arp
vehicle-router-ap#
> That's a bit tough due to all the customer specific data.  Here are some relevant snippets:
dot11 ssid (redacted)
   vlan 11
   authentication open eap eap_methods1
   authentication network-eap eap_methods1
   authentication key-management wpa
   accounting acct_methods1
   dot1x credentials TLS
   encryption mode ciphers tkip
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 ssid (redacted)
 antenna transmit right-a
 antenna receive right-a
 station-role workgroup-bridge universal 1cdf.0fcc.7052
 rts threshold 4000
 no cdp enable
 infrastructure-client
interface Dot11Radio0.11
 encapsulation dot1Q 11 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 spanning-disabled
interface FastEthernet0
 no ip address
 no ip route-cache
 speed auto
 full-duplex
interface FastEthernet0.11
 description IP address here needed to support SNMP signaling to MARC
 ip address 10.255.253.251 255.255.255.0
 no ip route-cache
 bridge-group 1
interface FastEthernet0.20
 description Sub-interface for consistent access/administration whether inside or outside of 802.11 coverage
 encapsulation dot1Q 20
 ip address 10.255.255.251 255.255.255.0
 no ip route-cache
 bridge-group 20
interface BVI1
 description Bridge Virtual Address - On Vlan11 from MARC's perspective
 ip address 10.255.254.251 255.255.255.0
 no ip route-cache
ip default-gateway 10.255.255.254
no ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
bridge 1 aging-time 120
bridge 20 aging-time 86400
> I have a monitor session on the switchport  the root AP is connected to
> I see the broadcasted DISCOVER from the WGB and a broadcasted OFFER.  There's no indication in the router receives it (based on the output from debug dhcp)
> yes.  Other clients (laptops/iPhones) also work when connecting to the root AP
on the AP of the 3200 add this subinterface :
interface Dot11Radio0.20
encapsulation dot1q 20
bridge-group 20
on the root AP, you can copy and paste :
add below :
bridge-group 20
encapsulation dot1q 11 native
bridge-group 1
bridge-group 20
bridge-group 1
dot11 ssid iotwifi
vlan 11
it should work ,
if not collect show bridge again from both sides .
