2504 Management over a separate Port
Mathias Bartz
Frequent Visitor
Frequent Visitor
is it possible to Manage the 2504 Controller over a separate Interface.
Exmaple:
Port 1 is used as controller management interface (untagged) - AP's are connected to the same VLAN
Port 1 is used for Guest Traffic (VLAN 3 tagged)
Port 2 should be used to manage the WLAN Controller from the internal LAN. (tested with untagged, tagged, same issue)
with this Setup it is possible to ping the Port 2 IP-Address from the internal LAN but if you try to connect to the controller,
the Browser shows "Site not reachable".
I also enabled "Management via Wireless" but without success.
I also tried to add the "management" VLAN as tagged on the management Interface with the same effect,
the controller is not manageable from the internal LAN.
On 5508 WLAN Controller i have an similar setup, but with LAG Port enabled. There this works.
The only interface were i can manage the WLAN controller is from the management Interface.
i hope someone can help me
kind regards
Mathias
George Stefanick
Yes, you need to drop in the CLI and issue this command
config network mgmt-via-dynamic-interface
BTW -- TAG EVERYTHING on the WLC.
__________________________________________________________________________________________
George Stefanick
