3502i will not join 5508
wjguest28
I have a 3502i(AP_1) that will not join a 5508 WLC(WLC_1)(code 7.2.103). The 3502i(AP_1) will join 4402 WLC(WLC_2)(Code 7.0.230). I have another 3502i(AP_2) that will join the WLC_1 & WLC_2. I am using capwap discover through DNS and hard coding the primiary WLC to AP_1 & AP_2. When I debug capwap events and errors, I see the static capwap messages and replies. Both of the WLC are on the same subnet. I have defauted the AP_1 and it joins the CISCO-CAPWAP-CONTROLLER as expected. When I change the Primiary WLC to WLC_1 it goes back to the CISCO-CAPWAP-CONTROLLER. If i change the primiary WLC to WLC_2 it joins. If I change the primiary back to WLC_1 it joins WLC_2 even though it is not a secondary. I know the previous joined WLC are stored in NVRAM, so that might be why it is doing that. I can join other ap to WLC_1 just not this one.
*spamApTask3: Sep 26 17:17:15.214: <<<<  Start of CAPWAP Packet  >>>>
*spamApTask3: Sep 26 17:17:15.214: CAPWAP Control mesg Recd from 10.22.110.3, Port 9360
*spamApTask3: Sep 26 17:17:15.214:              HLEN 4,   Radio ID 0,    WBID 1
*spamApTask3: Sep 26 17:17:15.214:              Msg Type   :   CAPWAP_PRIMARY_DISCOVERY_REQUEST
*spamApTask3: Sep 26 17:17:15.214:              Msg Length : 94
*spamApTask0: Sep 26 17:17:15.214: b4:14:89:83:d0:00 Received LWAPP PRIMARY_DISCOVERY_REQ from AP
*spamApTask3: Sep 26 17:17:15.214:              Msg SeqNum : 0
*spamApTask3: Sep 26 17:17:15.214:       Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask0: Sep 26 17:17:15.214: 00:14:f1:48:c0:00 Discarding Primary discovery request in LWAPP from AP supporting CAPWAP
*spamApTask3: Sep 26 17:17:15.214:              Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask3: Sep 26 17:17:15.214:       Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask3: Sep 26 17:17:15.214:              Maximum Radios Supported  : 2
*spamApTask3: Sep 26 17:17:15.214:              Radios in Use             : 2
*spamApTask3: Sep 26 17:17:15.214:              Encryption Capabilities   : 0x00 0x01
*spamApTask3: Sep 26 17:17:15.214:       Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask3: Sep 26 17:17:15.214:              WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask3: Sep 26 17:17:15.214:       Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask3: Sep 26 17:17:15.214:              WTP Mac Type  : SPLIT_MAC
*spamApTask3: Sep 26 17:17:15.214:       Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*spamApTask3: Sep 26 17:17:15.214:              Vendor Identifier  : 0x00409600
*spamApTask3: Sep 26 17:17:15.215:
        IE            :   UNKNOWN IE 207
*spamApTask3: Sep 26 17:17:15.215:      IE Length     :   4
*spamApTask3: Sep 26 17:17:15.215:      Decode routine not available, Printing Hex Dump
*spamApTask3: Sep 26 17:17:15.215: 00000000: 01 00 00 04                                       ....
*spamApTask3: Sep 26 17:17:15.215:       Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 17
*spamApTask3: Sep 26 17:17:15.215:              Vendor Identifier  : 0x00409600
        IE            :   RAD_NAME_PAYLOAD
*spamApTask3: Sep 26 17:17:15.215:      IE Length     :   11
*spamApTask3: Sep 26 17:17:15.215:      Rad  Name     :
*spamApTask3: Sep 26 17:17:15.215: AP_1
*spamApTask3: Sep 26 17:17:15.215: <<<<  End of CAPWAP Packet  >>>>
*spamApTask3: Sep 26 17:17:15.215: b4:14:89:83:d0:00 Primary Discovery Request from 10.22.110.3:9360
*spamApTask3: Sep 26 17:17:15.215: b4:14:89:83:d0:00 Join Priority Processing status = 0, Incoming Ap's Priority 4, MaxLrads = 50, joined Aps =0
*spamApTask3: Sep 26 17:17:15.215: b4:14:89:83:d0:00 Primary Discovery Response sent to  10.22.110.3:9360
wjguest28
More info:
------------------ show capwap client rcb ------------------
AdminState                  :  ADMIN_ENABLED
SwVer                       :  7.0.230.0
NumFilledSlots              :  2
MwarName                    :  WLC_2
MwarApMgrIp                 :  10.20.240.211
MwarHwVer                   :  0.0.0.0
ApMode                      :  Local
ApSubMode                   :  Not Configured
OperationState              :  UP
CAPWAP Path MTU             :  1485
LinkAuditing                :  disabled
AP Rogue Detection Mode     :  Enabled
AP Tcp Mss Adjust           :  Disabled
Band Direct                 :  Enabled
Predownload Status          :  None
Auto Immune Status          :  Disabled
------------------ show capwap client config ------------------
configMagicMark         0xF1E2D3C4
chkSumV2                39682
chkSumV1                3003
swVer                   7.0.230.0
adminState              ADMIN_ENABLED(1)
name                    AP_1
location                Somewhere
group name              No-WLANS
mwarName                WLC_1
mwarIPAddress           10.20.240.212
mwarName
mwarIPAddress           0.0.0.0
mwarName
ssh status              Enabled
Telnet status           Enabled
numOfSlots              2
spamRebootOnAssert      1
spamStatTimer           180
randSeed                0x0
transport               SPAM_TRANSPORT_L3(2)
transportCfg            SPAM_TRANSPORT_DEFAULT(0)
initialisation          SPAM_PRODUCTION_DISCOVERY(1)
ApMode                  Local
ApSubMode               Not Configured
AP Rogue Detection Mode Enabled
OfficeExtend AP         [0] Disabled
OfficeExtend AP JoinMode[0] Standard
Discovery Timer         10 secs
Heart Beat Timer        30 secs
Led State Enabled       1
Primed Interval         0
AP ILP Pre-Standard Switch Support Disabled
AP Power Injector Disabled
Infrastructure MFP validation Enabled
Configured Switch 1 Addr 10.20.240.210
non-occupancy channels:
Ethernet (Duplex/Speed) auto/auto
AP_1# ping WLC_1
Sending 5, 100-byte ICMP Echos to 10.20.240.212, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
can you grab a screen shot of the Security > AP Policies?
Also a debug mac addr < ap mac> debug capwap events enable , debug capwap errors enable
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
AP Policies are the same on the 4400 WLC_2
I ran enabled the debugs you requested and there are no events. It is like the AP stops trying to contact WLC_1 and goes stright to WLC_2. If I default the AP then the debug events that are displayed above are what is shown. Attached is AP_1 boot from console.
