2504 Power issues - Is this the same brick used on an ASA?
gp1200x
Level 2
Level 2
I have a 2504 that will not light up. No leds on the front.  Appears to have power on the brick.
Question - can I use a ASA 5505 power supply on these too?  They also have a 48V supply and the plug is the same. Just not sure if the + and - are the same pins and have no meter around.
Leo Laohoo
The answer is "yes" but I won't be held responsible if anything should happen.
Leo Laohoo
tasneemjan
Did asa 5505 power supply worked with wlc 2504?
