2700 Location Appliance Problem
andrewswanson
Level 7
Level 7
we've recently been sent a 2700 location appliance by Cisco to evaluate. unfortunatley i've 'broken' it already!
the 2700 came with software 2.0 and i upgraded it manually to latest v4.
after the upgrade i got java exception errors when i ran the command /opt/locserver/bin/getserverinfo so i downloaded latest version of 2.0 and installed that.
when i run /opt/locserver/bin/getserverinfo i get the following:-
[root@loc-server root]# /opt/locserver/bin/getserverinfo
com.aes.client.AesClientException: Failed to connect to server: http://localhost:8001
at com.aes.client.AesClient.connect(Unknown Source)
at com.aes.location.test.AesAbstractTest.init(Unknown Source)
at com.aes.location.test.admin.AesTestGetServerInfo.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
the server is started but i can't stop it - i get the following when i try:-
[root@loc-server root]# /etc/init.d/locserverd start
Starting locserverd:
[root@loc-server root]# /etc/init.d/locserverd stop
Shutting down locserverd: com.aes.client.AesClientException: Failed to connect to server: http://localhost:8001
at com.aes.location.test.admin.AesTestShutdown.main(Unknown Source)
the 2700 can't be managed by WCS and i can't start/stop the location server. when i try and uninstall/install i get the message that:-
Server is still running, stop the server and try again...
any help appreciated
thanks
andy
andrewswanson
Level 7
Level 7
fixed this - manually killed the locserverd process and could then uninistall the server - after reinstall i can now connect the location appliance to the WCS
andy
