11-08-2024 12:00 PM
Hi Guys,
I have a situation where my users cannot connect their WIFI/SSID using their iPhone. However, for android users they have no issue with the wifi; I believe their iPhone has updated with the latest IOS version.
The current firmware version of my Controller 3800 and AP 2800 are 8.5.131.0.
Appreciate your ideas and thoughts.
11-16-2024 02:02 AM
> will it automatically upgrade my APs as well?
No. Mobility Express does not store all AP images like regular WLC.
You must provide the images on a TFTP server and configure the TFTP server details on the Mobility Express controller. Otherwise you'll need to upgrade each AP manually.
https://www.wiresandwi.fi/blog/cisco-mobility-express-software-upgrade
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_01000.html#task_4387C8D3ADCA4D9EA365763A1DA5B2E2
Plenty of other guides and videos too if you search.
12-20-2024 10:43 AM
Hi @marce1000
appreciate your help on this. I did perform the upgrade based on your ideas and recommendation. Really appreciate it.
However seems like the upgrade failed based on the screenshot attached. Im not too sure is it related with tftp blocksize or whatelse? because based on my observation, from the TFTP the process kept restarting after reaching approximately 30%. This cycle continued repeatedly for the entire 12-hour process. I’ve attached the updated logs from TFTP for your further reference. Any ideas how to solve this?
11-08-2024 12:48 PM
@AlfianZaini Please provide more detail about how SSID is configured ? Is it wpa2 personal or wpa3 personal? or wpa2 enterprise?
As a general recommendation always go with supported code version.
Latest supported (8.10.196.0)
Cisco Aironet 3800 Series Access Points - Cisco
hope that helps.
********Please rate all usefull response*****
11-08-2024 04:06 PM
Hi @srimal99 , they way I configure the SSID is wpa2 personal. Noted on the recommendation by upgrading the firmware to the latest version which is 8.10.196.0.
May I know do you have any reference or guide how to perform the firmware upgrade? I have download the zip file of 8.10.196.0.
Thank you.
11-08-2024 05:52 PM
@AlfianZaini refer to link below.
Cisco Aironet 3800 Series Access Points - Install and Upgrade Guides - Cisco
11-08-2024 12:56 PM
Can you share SSID configuration details.
Have you enabled Fast SSID change?
Please go through the configuration best practices..
Jagan Chowdam
/**Pls rate useful responses**/
11-08-2024 04:09 PM
The current SSID configuration is WPA2 personal and with fast SSID enabled.
Fast SSID Change ........................... Enabled
11-08-2024 02:43 PM
Reboot the APs.
11-08-2024 04:09 PM
It is not working in my case
11-08-2024 05:08 PM
What error message did the Apple clients report.
Do a debug one of the Apple wireless client attempts to authenticate. Post the complete debug.
