3502E as Autonomous Web GUI problem
omnibus
Visitor
Hi Everyone,
I have an AIR-CAP3502E-A-K9 with the autonomous (AP3G1-K9W7-M), Version 15.3(3)JF12, RELEASE SOFTWARE (fc1)
All the CLI works as expected but the Web GUI give me a "404 not found error" anytime I press the Apply button to push a new configuration.
Anyone of you are experiencing the same problem or get it sorted in some way?
Rasika Nayanajith
If the AP model got the latest image I would try with that code. If not I would stick with CLI for configuration.
Since it is autonomous codes, there is no development to fix defects (if this is one of them).
Rasika
*** Pls rate all useful responses **
The software is supported and still developed by Cisco up to 2021. I don't know who invented the story about autonomous software is not developed and maintained. I have both the latest released in May and February and both having the same problem.
Actually @omnibus Cisco announce it themselves very clearly: https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-3500-series/eos-eol-notice-c51-734304.html - nobody is 'inventing' anything - it's simple FACT!
End of SW Maintenance Releases Date: HW The last date that Cisco Engineering may release any final software maintenance releases or bug fixes. After this date, Cisco Engineering will no longer develop, repair, maintain, or test the product software. March 31, 2017 <<<<<<<
They sometimes produce fixes for things like critical security vulnerabilities after that date at their own discretion (and you might get lucky and pick up a bug fix or 2 at the same time) but if you report a bug now it will NOT get fixed.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
This is an issue that others also had. It looks like a browser compatibility issue. One solution others posted, was to go back one or two releases for this AP model.
You could try it in Edge in Internet Explorer compatibility mode (press F12).
