08-20-2018 08:53 AM - edited 07-05-2021 09:00 AM
Trying to setup a wireless bridge between 2 1542 and a 3504. I have the 1542 joined to the controller and under the wireless tab set in bride mode but on APSub Mode i can not select a different function. Under AAA/mac filtering they are added in there.WLAN tab there is a group created anf the AP are part of the group. i have the "slave" connected to a 3560 receiving poe that is configured correctly and can ping the switch controller and both AP. Im missing a step can anyone help?
08-20-2018 08:39 PM
What code you running on your 3504 ?
Rasika
08-21-2018 06:22 AM
8.5.135
08-21-2018 02:16 PM
I think you are with a recommended code. As per release notes there is no indication of 1542 having any issues with Mesh mode
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr3.html
If there is a chance to test, I would see if you see same behavior with different AireOS version (eg 8.8.100.0)
Rasika
