Cisco ISE and Wireless options
Kudetauk77
Evening All,
I have a few questions regarding Wireless WLC and ISE , The best way to configure the following .
1. A guest network that can use a token to login and change every day,week etc.  I see the token option on ISE but cannot find any documentation on it .
2. Corp Wifi that uses AD to authenticate users .
I have successfully enabled VPN access with anyconnect to allow the ISE to authenticate users in AD to log into specific Tunnel groups and then use a Downloadable ACL to restric access per group in AD .
Would it be something similar , any detailed help would be great .
Craig
HI Craig,
Below document should help you on that
https://community.cisco.com/t5/wireless-mobility-documents/integration-of-ise-identity-services-engine-with-cisco-wlc/ta-p/3109883
Rasika
*** Pls rate all useful responses ***
