06-27-2013 08:16 AM - edited 07-04-2021 12:18 AM
Hello
Has anyone experience or know if its possible to join 4400 wlc and 5508 to the same mobility group? Can't find much info out there, just want to find out if there are any gotchas.
Solved! Go to Solution.
06-27-2013 08:30 AM
Yes you can but reference this link.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp123314
06-27-2013 08:30 AM
