04-22-2008 08:08 AM - edited 07-03-2021 03:45 PM
I have WCS and 4402 WLC and would like to deploy access points in different builds all controlled from this single WLC. I'd like each building and ap's in the building have their own WLAN/ssid.
All the buildings are connected, via fiber to main campus switch where the WLC is located.
Can i do this and can someone point me in the right direction?
TIA
craig
Solved! Go to Solution.
04-22-2008 10:07 AM
You can use wlan override to do this
It is located on the controller under Wireless|Access Points|802.11b/g/n or 802.11a/n
04-22-2008 10:07 AM
04-22-2008 12:53 PM
That did the trick!
Thanks Eric
