4402 Controller question
joeadiutori
Level 3
Level 3
Hi All,
We have a 4402 Wireless Controller.  However, our AP's are from another manufacturer (Meraki MP12).  Is it possible that the 4402 can "control" the Meraki MP12?
Thanks - Joe
Is it fair to say that the Cisco 4402 controller will only support Cisco AP's?
This is correct.
The Cisco WLC will NOT support the AP540 nor the Linksys-branded WAP.
The Release Notes will tell you which firmware will support which WAP models.
8 Replies 8
Scott Fella
If you take a look at the release note, depending on what code versions, it will the supported equipment... Of course it is all Cisco gear.
-Scott
Scott Fella
I would have to say no.
Scott Fella
Sent from my iPhone
-Scott
Leo Laohoo
No.
Leo,
Can I take it a step further?  Is it fair to say that the Cisco 4402 controller will only support Cisco AP's?
Thanks again.
This is correct.
Good.  That's what I wanted to hear.  Thank You !!
Sorry, you were too fast.  I edited my last post to provide further information.
Thanks for the ratings.
Yes... It will list the supported devices in the release notes.
Scott Fella
Sent from my iPhone
-Scott
