4402 WLC connection and setup
Cisco1619
I am setting up a 4402 WLC on my home lab and can't get the management port to work. I have the web interface through the service port working. I was hoping someone could help. My home lab has the switches, an 881W, and two 871. Each of these three units have the same basic set up of 4 L2 switch ports and one L3 WAN port. I have the 881W as the switch the service port connects to. The ip of the switch is 10.1.1.1, with the service port connected at 10.1.1.4. The WAN port on the 881W connects to the WAN port of one of the 871 switches. The have ip addresses of 192.168.1.1 and .2. The second 871 is connected to the first 871 through a L2 trunk port. The ip of the 871s are 10.2.1.1 and 10.2.1.2. I have the management port of the WLC connected to the second 871 through it's WAN port at 10.10.1.1. The management interface for the WLC is 10.10.1.5 and the AP-manager is 10.10.1.6 through port 2 of the 4402. Under port statistics in the WLC I see packet received and transmitted, so it appears the there is a connection.
I have moved the management port to a L2 connection on the second 871 and changed the ip accordingly, but it still does not respond to pings. I have not been able to get this up and going. Any help would be greatly appreciated.
8 Replies 8
Stephen Rodriguez
What is the config for the management interface and for the port it connects to?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella
Your setup is really not standard. First off the service port on the 4400 is for out of band and should not be connected to the network. The IP address should also be something that is not used in your network thus not routable. The management and the ap manager interface needs to be on the same subnet and either tagged or not tagged. If you have set the vlan to 0 when you went the ought the startup wizard, then the trunk port the WLC is connected to should have a native vlan configured. If you specified a vlan, then you just need to make sure the vlan is allowed. If you have the WLC connected to an access port, then the management vlan should be untagged, set to 0.
-Scott
I have tried what you said, but I am still unable to get the management port up. I will try to get the configs tomorrow. Does this have to connect to an access port, L3 port, or does it matter if the configs are correct? Does there need to be any routes on the WLC set up?
It needs to be connected to a single switch via a trunk port (use only one port on the WLC).  You need to post your config and the switch config.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Here is the configuration for the controler management port and the switch I have it connected to. Currently I have it on a L2 connection.
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 00:24:c4:e6:38:80
IP Address....................................... 10.2.1.5
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.2.1.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 2
Primary Physical Port............................ 2
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.2.1.2
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
version 12.4
no service pad
service password-encryption
hostname R3_871
boot-start-marker
boot-end-marker
enable secret 5 $1$ev6X$HjtwiFNNxEcL0vkOUxdrA.
no aaa new-model
crypto pki trustpoint TP-self-signed-2690146388
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2690146388
revocation-check none
rsakeypair TP-self-signed-2690146388
crypto pki certificate chain TP-self-signed-2690146388
certificate self-signed 01
!!!!Eliminating for clarity!!!!
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.2.1.128 10.2.1.135
ip dhcp pool Home_Lab
   network 10.2.1.128 255.255.255.128
   default-router 10.2.1.2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
username !!!removed!!!
archive
log config
  hidekeys
interface FastEthernet0
switchport access vlan 20
switchport mode trunk
interface FastEthernet1
switchport access vlan 30
interface FastEthernet2
interface FastEthernet3
description WLC Connection
interface FastEthernet4
ip address 10.10.1.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan20
ip address 10.2.1.2 255.255.255.0
interface Vlan30
no ip address
ip forward-protocol nd
ip route 10.1.1.0 255.255.255.0 10.2.1.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
line con 0
privilege level 15
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
logging synchronous
login local
scheduler max-task-time 5000
end
R3_871#sh int statu
Port    Name               Status       Vlan       Duplex Speed Type
Fa0                                        connected    trunk      a-full   a-100 10/100BaseTX
Fa1                                        notconnect   30           auto    auto 10/100BaseTX
Fa2                                        notconnect   20           auto    auto 10/100BaseTX
Fa3     WLC Connection     connected    trunk      a-full   a-100 10/100BaseTX
Thanks for the help!
Tag your management interface to the appropriate management VLAN, 20.
Where is this?
What is this router?  Exactly, what model?  I can see you've created an interface VLAN, where's the VLAN in relations with the VLAN database?  I don't see that.
Can you post the output to the WLC command of "sh cdp nei det"?
Abhishek Abhishek
As per the config posted by you I can see that the issue of default gateway and the encapsulation type is not configured on the switch.
Jacob Snyder
Level 5
Level 5
4400 requires a 1000Mbps (gig) port and they don't support 100Mbps speed.. All the ports on 881W and 871 are 100Mbps.
