06-09-2015 10:44 AM - edited 07-05-2021 03:22 AM
I am troubleshooting an issue where a 5508 which is hosted behind and ASA5512 is losing management access when we go over about 70 AP's
It has been running perfectly for many weeks with 34 AP's and I have now brought another office online and the AP count has gone up to 70+
I lose management access and also some AP's are stuck in the green/red light cycle.
The WLC is licensed for 150 AP's following an upgrade from 50 to 150
What could be causing the loss of management access?
I am suspecting something on the firewall?
If I shut down the vlan for the new office management access is restored.
SSH access to the controller works fine throughout
Roger
06-09-2015 02:41 PM
Which software are you running on your 5508?
Is the traffic being NAT'ed on the ASA? And what is the status of the incoming connections on the ASA when this happends?
show conn | include 1.1.1.1 (IPv4 of the WLC)
06-09-2015 03:22 PM
Traffic is not being NATéd
Running 7.6.130.0 - 3702 APs
I will find out the status of the connections tmw.
I suspected an issue on the WLC but it can be easily fixed by dropping some AP's
There must be some resource exhaustion on the ASA or connection limit?
06-10-2015 05:37 AM
Problem solved - there was another firewall in the path which was limiting connections to a single IP
