5508 Web Authtenication w/Encryption and LDAP?
lcaruso
Level 6
Level 6
From what I've read, it doesn't seem possible to use Web Authentication and obtain encryption unless using a Radius server.
I have a client asking for web auth, encryption, and ldap connection to their AD servers.
Not possible, right?
Thanks.
ahh, no.  Encryption happens at layer 2.  So you would need to configure the WLAN for EAP to be able to use the LDAP and get encryption.
With just webauth, you can use LDAP for the user/pass but you won't get encryption.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
Not true.  you can use a PSK with webauth.
HTH,
Steve
HTH,
Steve
Thanks. I stated the question in misleading fashion.
I understand I can use both L2 and L3 authentication, so my question was intended to read:
If I only use Layer 3 authentication, can I get web auth, encryption, and ldap connection to their AD servers.
HTH,
Steve
HTH,
Steve
Thanks. That's what I had understood, but it's good to hear a confirmation.
