5520HA making high Noise from Fan
Mohamed.Ashraf
I Have 2 5520 WLCs working as active and standby. Every hour or a half of hour i hearing a huge noise  from FAN although they still working fine.
IOS Software : 8.3.143
Thank you
6 Replies 6
Sandeep Choudhary
You needs to access the CMIC, go to FAN Control Policies and change "Maximum" to "Performance" .
1: Log into CIMC
2: On the Server Tab click Power Policies
3: Change Fan Policies under the Configured Fan Policy Section to "Performance"
4: Click Save Changes
5: Server Will automatically Reboot and thats it.
Dont forget to rate helpful posts
I have seen this on a few versions of code, and when i upgraded it went away.  If the CIMC option doesn't fix it, you could look at a version upgrade.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Rasika Nayanajith
Pls check what speed those fans are running ?
I am running 8.5.140.0 on our 5520 & see below values. If you see higer RPM rates in yours, then upgrade to 8.5.151.0.
(5520-WLC2) >show imm chassis fan
FAN1_TACH1 | 0Fh | ok | 29.1 | 4800 RPM
FAN1_TACH2 | 10h | ok | 29.1 | 5700 RPM
FAN2_TACH1 | 11h | ok | 29.2 | 4800 RPM
FAN2_TACH2 | 12h | ok | 29.2 | 5500 RPM
FAN3_TACH1 | 13h | ok | 29.3 | 4800 RPM
FAN3_TACH2 | 14h | ok | 29.3 | 5700 RPM
FAN4_TACH1 | 15h | ok | 29.4 | 4800 RPM
FAN4_TACH2 | 16h | ok | 29.4 | 5800 RPM
FAN5_TACH1 | 17h | ok | 29.5 | 4800 RPM
FAN5_TACH2 | 18h | ok | 29.5 | 5700 RPM
FAN6_TACH1 | 19h | ok | 29.6 | 4800 RPM
FAN6_TACH2 | 1Ah | ok | 29.6 | 5700 RPM
Rasika
*** Pls rate all useful responses ***
Hi Rasika
(Cisco Controller) >show imm chassis fan
FAN1_TACH1       | 0Fh | ok  | 29.1 | 5200 RPM
FAN1_TACH2       | 10h | ok  | 29.1 | 6300 RPM
FAN2_TACH1       | 11h | ok  | 29.2 | 5200 RPM
FAN2_TACH2       | 12h | ok  | 29.2 | 6300 RPM
FAN3_TACH1       | 13h | ok  | 29.3 | 5200 RPM
FAN3_TACH2       | 14h | ok  | 29.3 | 6300 RPM
FAN4_TACH1       | 15h | ok  | 29.4 | 5100 RPM
FAN4_TACH2       | 16h | ok  | 29.4 | 6100 RPM
FAN5_TACH1       | 17h | ok  | 29.5 | 5200 RPM
FAN5_TACH2       | 18h | ok  | 29.5 | 6300 RPM
FAN6_TACH1       | 19h | ok  | 29.6 | 5100 RPM
FAN6_TACH2       | 1Ah | ok  | 29.6 | 6300 RPM
It is normal or not.
Thank you
Could be normal, based on the temperature reading. Please note that the fans are temperature controlled. So if your server room is fairly warm, then they run quicker.
I also have seen different behavior with different WLC code releases.
Please also note the CIMC upgrade for the 5520, which you probably are missing: http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr5.html#cimc-upgrade
That upgrades all the firmwares for the server and might also change some temperature points.
I think it is normal.
Rasika
