6Ghz Roaming Problems
I am testing out a setup before permanent installation.  I have 4x CW9166I-B access points, and 1x C9120AXP-B with an external outdoor antenna running on a Catalyst 9800-L Wireless Controller software version 17.13.1.  When I am running only 2.4 and 5Ghz radios everything works as expected, and I can roam between access points dropping just one or two pings.  When I enable the 6Ghz radios I drop a minimum of 4 pings, and often times far more as the laptop often times disassociates, and takes up to a minute to re-associate.  Manually turning the wireless off and then back on connects things back up immediately.  I only have one 6Ghz capable device to test with, it is an Intel(R) Wi-Fi 6E AX210 160MHz running driver version 23.20.0.4 on Windows 11.  I have run https://cway.cisco.com/wireless-config-analyzer/ and do not see anything potentially related to this issue.  A debug trace on the client shows some interesting errors I cannot quite explain:
2024/01/18 10:34:53.159977223 {wncd_x_R0-0}{1}: [dot11] [15753]: (info): MAC: 3089.4a58.57cd DOT11 state transition: S_DOT11_ASSOCIATED -> S_DOT11_DELETED
2024/01/18 10:34:53.160215217 {wncd_x_R0-0}{1}: [client-orch-sm] [15753]: (ERR): MAC: 0000.0000.0000 Unable to determine vlan and switching mode. fsm_ctxt not found for client
2024/01/18 10:34:53.160289513 {wncd_x_R0-0}{1}: [client-orch-sm] [15753]: (ERR): MAC: 0000.0000.0000 Unable to determine vlan and switching mode. fsm_ctxt not found for client
2024/01/18 10:34:53.160363000 {wncd_x_R0-0}{1}: [client-orch-sm] [15753]: (ERR): MAC: 0000.0000.0000 Unable to determine vlan and switching mode. fsm_ctxt not found for client
2024/01/18 10:34:53.160441434 {wncd_x_R0-0}{1}: [client-orch-sm] [15753]: (ERR): MAC: 0000.0000.0000 Unable to determine vlan and switching mode. fsm_ctxt not found for client
2024/01/18 10:34:53.160783697 {wncd_x_R0-0}{1}: [caaa-acct] [15753]: (info): [CAAA:ACCT] Not a webauth call
2024/01/18 10:34:53.160926754 {wncd_x_R0-0}{1}: [dot11] [15753]: (debug): MAC: 3089.4a58.57cd Dot11 SAE finds ipsk progress as 0, not in pending state
2024/01/18 10:34:53.161060433 {wncd_x_R0-0}{1}: [auth-mgr] [15753]: (info): [3089.4a58.57cd:capwap_90000014] Stopped Persistent Reauth Timer for Client 3089.4a58.57cd
2024/01/18 10:34:53.422086830 {wncd_x_R0-0}{1}: [site-manager-ap] [15753]: (ERR): Failed to get flex interface name vlan table root
2024/01/18 10:34:53.436263826 {wncd_x_R0-0}{1}: [site-manager-ap] [15753]: (ERR): Failed to get first entry for vlan name-id table
2024/01/18 10:34:53.449453412 {wncd_x_R0-0}{1}: [sisf-packet] [15753]: (ERR): Unexpected IPv6 packet glean in Local-switcing mode fe80::b644:bd1:6b47:41e6 : 3089.4a58.57cd in at vlan
2 Accepted Solutions
It's not that much the difference in signal range from swapping from 5- to 6-GHz, but there are huge differences when it comes to client's adapters using 6-GHz band (https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/ghz-unlicensed-spectrum-reg-wp.html#:~:text=The%20output%20power%20in%20the%206%20GHz%20band%20varies%20greatly%2C%20from%204%20to%2016%20dBm%2C%20depending%20on.... Notice that there is a 4dBm reduction in the maximum TX power a client can use from 5- to 6-GHz, and then add the quality of the NIC and the maximum power that is allowed to be used from the manufacturer (Check this out from Intel https://fccid.io/PD9AX211D2L?utm_content=cmp-true)
cisco.koernerc
Visitor
I know the post was opened some time ago, but if you still have this issues, try to disable Client Analytics completely in the WLAN Profile. It is a great feature but seems to cause lot of issues with Samsung S2x series and Intel WiFI chips in WIN Clients in combination with 6GHz .........
30 Replies 30
Leo Laohoo
Under the configuration for the Intel wireless NIC is an option called "Roaming Aggressiveness" and, by default, it is set to 3.
I have now turned it up to the highest now (5) and unfortunately it did not
make a difference.
Mark Elsen
               >...Unable to determine vlan and switching mode. fsm_ctxt not found for client
       - Informational only : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwd22364
 M,
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for finding that bug post.  It is now the second error in this troubleshooting process where what looks like a major error is actually normal.  Unfortunately now I have almost nothing that points to why 6Ghz roams so poorly in comparison to 5/2.4Ghz
Haydn Andrews
Is the SSID WPA3 or WPA3 transition mode? If you can set it to WPA3 only and retest. Heard some stories of roaming issues in transition mode (especially if PSK)
*****Help out other by using the rating system and marking answered questions as "Answered"*****
To eliminate as many variables as possible, I went full WPA3 and have even
tried turning off 2.4/5GHz radios on the SSID. It did not help.
Post the complete output to the following commands:
sh ap dot11 6 network
sh ap dot11 6 summary
809-9800WLC#sh ap dot11 6 network
802.11 6Ghz Network : Enabled
802.11 6Ghz Status:
A-MPDU Tx:
Priority 0 : Enabled
Priority 1 : Enabled
Priority 2 : Enabled
Priority 3 : Enabled
Priority 4 : Enabled
Priority 5 : Enabled
Priority 6 : Disabled
Priority 7 : Disabled
A-MSDU Tx:
Priority 0 : Enable
Priority 1 : Enable
Priority 2 : Enable
Priority 3 : Enable
Priority 4 : Enable
Priority 5 : Enable
802.11ax : Enabled
DynamicFrag : Enabled
MultiBssid : Enabled
Target Wakeup Time : Disabled
Target Wakeup Time Broadcast : Disabled
BSS Color : Disabled
OBSS PD : Disabled
Non-SRG OBSS PD Maximum Threshold : -62 dBm
SRG OBSS PD : Disabled
SRG OBSS PD Minimum Threshold : -82 dBm
802.11ax MCS Settings:
MCS 7, Spatial Streams = 1 : Supported
MCS 9, Spatial Streams = 1 : Supported
MCS 11, Spatial Streams = 1 : Supported
MCS 7, Spatial Streams = 2 : Supported
MCS 9, Spatial Streams = 2 : Supported
MCS 11, Spatial Streams = 2 : Supported
MCS 7, Spatial Streams = 3 : Supported
MCS 9, Spatial Streams = 3 : Supported
MCS 11, Spatial Streams = 3 : Supported
MCS 7, Spatial Streams = 4 : Supported
MCS 9, Spatial Streams = 4 : Supported
MCS 11, Spatial Streams = 4 : Supported
Beacon Interval : 100
CF Pollable mandatory : Disabled
CF Poll Request Mandatory : Disabled
CFP Period : 4
CFP Maximum Duration : 60
Default Channel : 1
Default Tx Power Level : 1
DTPC Status : Enabled
Fragmentation Threshold : 2346
RSSI Low Check : Disabled
RSSI Threshold : -127 dbm
TI Threshold :
Legacy Tx Beamforming setting : Disabled
Traffic Stream Metrics Status : Disabled
Expedited BW Request Status : Disabled
EDCA profile type check : fastlane
Client Load Based EDCA Config : Enabled
Call Admision Control (CAC) configuration
Voice AC
Voice AC - Admission control (ACM) : Disabled
Voice Stream-Size : 84000
Voice Max-Streams : 2
Voice Max RF Bandwidth : 75
Voice Reserved Roaming Bandwidth : 6
Voice Load-Based CAC mode : Enabled
Voice tspec inactivity timeout : Enabled
CAC SIP-Voice configuration
SIP based CAC : Disabled
SIP call bandwidth : 64
SIP call bandwith sample-size : 20
Maximum Number of Clients per AP Radio : 200
WiFi to Cellular RSSI Threshold : -85 dbm
Client Network Preference : default
809-9800WLC#sh ap dot11 6 summary
* global assignment
^ global assignment not adhering to configuration due to AFC restriction
~ global assignment comply with AFC operating in Standard Power Mode
AP Name Mac Address Slot Admin State Oper State Width Txpwr Channel Mode
LivingRoom 7411.b2aa.7c60 2 Enabled Up 160 *1/8 (23 dBm) (197,193,201,205,209,213,217,221)* REAP
Lori 7411.b2d8.2dc0 2 Enabled Up 160 *1/8 (23 dBm) (101,97,105,109,113,117,121,125)* REAP
Basement 7411.b2d8.2e00 2 Enabled Up 160 *1/8 (23 dBm) (21,17,25,29,1,5,9,13)* REAP
Bedroom 7411.b2d8.37a0 2 Enabled Up 160 *1/8 (23 dBm) (53,49,57,61,33,37,41,45)* REAP
809-9800WLC#
Forgot another command:  sh ap auto-rf dot11 6
809-9800WLC#sh ap auto-rf dot11 6
Number of Slots : 3
AP Name : LivingRoom
MAC Address : 7411.b2aa.7c60
Ethernet MAC Address : 149f.430c.1bf0
Slot ID : 2
Radio Type : 802.11ax - 6 GHz
Current TX/RX Band : 6Ghz band
Subband Type : All
Noise Information
Noise Profile : Passed
Channel 1 : -101 dBm
Channel 5 : -101 dBm
Channel 9 : -101 dBm
Channel 13 : -101 dBm
Channel 17 : -100 dBm
Channel 21 : -101 dBm
Channel 25 : -100 dBm
Channel 29 : -100 dBm
Channel 33 : -101 dBm
Channel 37 : -100 dBm
Channel 41 : -100 dBm
Channel 45 : -100 dBm
Channel 49 : -100 dBm
Channel 53 : -100 dBm
Channel 57 : -101 dBm
Channel 61 : -101 dBm
Channel 65 : -101 dBm
Channel 69 : -101 dBm
Channel 73 : -101 dBm
Channel 77 : -101 dBm
Channel 81 : -101 dBm
Channel 85 : -101 dBm
Channel 89 : -101 dBm
Channel 93 : -101 dBm
Channel 97 : -101 dBm
Channel 101 : -101 dBm
Channel 105 : -101 dBm
Channel 109 : -101 dBm
Channel 113 : -101 dBm
Channel 117 : -101 dBm
Channel 121 : -101 dBm
Channel 125 : -101 dBm
Channel 129 : -101 dBm
Channel 133 : -101 dBm
Channel 137 : -101 dBm
Channel 141 : -101 dBm
Channel 145 : -101 dBm
Channel 149 : -101 dBm
Channel 153 : -101 dBm
Channel 157 : -101 dBm
Channel 161 : -101 dBm
Channel 165 : -101 dBm
Channel 169 : -101 dBm
Channel 173 : -101 dBm
Channel 177 : -101 dBm
Channel 181 : -101 dBm
Channel 185 : -101 dBm
Channel 189 : -101 dBm
Channel 193 : -101 dBm
Channel 197 : -101 dBm
Channel 201 : -101 dBm
Channel 205 : -101 dBm
Channel 209 : -101 dBm
Channel 213 : -101 dBm
Channel 217 : -101 dBm
Channel 221 : -101 dBm
Channel 225 : -101 dBm
Channel 229 : -101 dBm
Channel 233 : -101 dBm
Interference Information
Interference Profile : Passed
Channel 1 : -128 dBm @ 5% busy
Channel 5 : -128 dBm @ 4% busy
Channel 9 : -128 dBm @ 3% busy
Channel 13 : -128 dBm @ 26% busy
Channel 17 : -128 dBm @ 23% busy
Channel 21 : -128 dBm @ 14% busy
Channel 25 : -128 dBm @ 9% busy
Channel 29 : -128 dBm @ 18% busy
Channel 33 : -128 dBm @ 11% busy
Channel 37 : -128 dBm @ 17% busy
Channel 41 : -128 dBm @ 16% busy
Channel 45 : -128 dBm @ 0% busy
Channel 49 : -128 dBm @ 12% busy
Channel 53 : -128 dBm @ 8% busy
Channel 57 : -128 dBm @ 12% busy
Channel 61 : -128 dBm @ 9% busy
Channel 65 : -128 dBm @ 2% busy
Channel 69 : -128 dBm @ 3% busy
Channel 73 : -128 dBm @ 17% busy
Channel 77 : -128 dBm @ 9% busy
Channel 81 : -128 dBm @ 31% busy
Channel 85 : -128 dBm @ 10% busy
Channel 89 : -128 dBm @ 11% busy
Channel 93 : -128 dBm @ 17% busy
Channel 97 : -128 dBm @ 16% busy
Channel 101 : -128 dBm @ 14% busy
Channel 105 : -128 dBm @ 21% busy
Channel 109 : -128 dBm @ 5% busy
Channel 113 : -128 dBm @ 18% busy
Channel 117 : -128 dBm @ 0% busy
Channel 121 : -128 dBm @ 4% busy
Channel 125 : -128 dBm @ 4% busy
Channel 129 : -128 dBm @ 4% busy
Channel 133 : -128 dBm @ 3% busy
Channel 137 : -128 dBm @ 4% busy
Channel 141 : -128 dBm @ 5% busy
Channel 145 : -128 dBm @ 5% busy
Channel 149 : -128 dBm @ 0% busy
Channel 153 : -128 dBm @ 31% busy
Channel 157 : -128 dBm @ 6% busy
Channel 161 : -128 dBm @ 8% busy
Channel 165 : -128 dBm @ 1% busy
Channel 169 : -128 dBm @ 11% busy
Channel 173 : -128 dBm @ 2% busy
Channel 177 : -128 dBm @ 30% busy
Channel 181 : -128 dBm @ 6% busy
Channel 185 : -128 dBm @ 6% busy
Channel 189 : -128 dBm @ 0% busy
Channel 193 : -128 dBm @ 0% busy
Channel 197 : -128 dBm @ 0% busy
Channel 201 : -128 dBm @ 0% busy
Channel 205 : -128 dBm @ 0% busy
Channel 209 : -128 dBm @ 0% busy
Channel 213 : -128 dBm @ 0% busy
Channel 217 : -128 dBm @ 0% busy
Channel 221 : -128 dBm @ 0% busy
Channel 225 : -128 dBm @ 5% busy
Channel 229 : -128 dBm @ 0% busy
Channel 233 : -128 dBm @ 12% busy
Rogue Histogram (20/40/80)
Channel 1 : 0/ 0/ 0
Channel 5 : 0/ 0/ 0
Channel 9 : 0/ 0/ 0
Channel 13 : 0/ 0/ 0
Channel 17 : 0/ 0/ 0
Channel 21 : 0/ 0/ 0
Channel 25 : 0/ 0/ 0
Channel 29 : 0/ 0/ 0
Channel 33 : 0/ 0/ 0
Channel 37 : 0/ 0/ 0
Channel 41 : 0/ 0/ 0
Channel 45 : 0/ 0/ 0
Channel 49 : 0/ 0/ 0
Channel 53 : 0/ 0/ 0
Channel 57 : 0/ 0/ 0
Channel 61 : 0/ 0/ 0
Channel 65 : 0/ 0/ 0
Channel 69 : 0/ 0/ 0
Channel 73 : 0/ 0/ 0
Channel 77 : 0/ 0/ 0
Channel 81 : 0/ 0/ 0
Channel 85 : 0/ 0/ 0
Channel 89 : 0/ 0/ 0
Channel 93 : 0/ 0/ 0
Channel 97 : 0/ 0/ 0
Channel 101 : 0/ 0/ 0
Channel 105 : 0/ 0/ 0
Channel 109 : 0/ 0/ 0
Channel 113 : 0/ 0/ 0
Channel 117 : 0/ 0/ 0
Channel 121 : 0/ 0/ 0
Channel 125 : 0/ 0/ 0
Channel 129 : 0/ 0/ 0
Channel 133 : 0/ 0/ 0
Channel 137 : 0/ 0/ 0
Channel 141 : 0/ 0/ 0
Channel 145 : 0/ 0/ 0
Channel 149 : 0/ 0/ 0
Channel 153 : 0/ 0/ 0
Channel 157 : 0/ 0/ 0
Channel 161 : 0/ 0/ 0
Channel 165 : 0/ 0/ 0
Channel 169 : 0/ 0/ 0
Channel 173 : 0/ 0/ 0
Channel 177 : 0/ 0/ 0
Channel 181 : 0/ 0/ 0
Channel 185 : 0/ 0/ 0
Channel 189 : 0/ 0/ 0
Channel 193 : 0/ 0/ 0
Channel 197 : 0/ 0/ 0
Channel 201 : 0/ 0/ 0
Channel 205 : 0/ 0/ 0
Channel 209 : 0/ 0/ 0
Channel 213 : 0/ 0/ 0
Channel 217 : 0/ 0/ 0
Channel 221 : 0/ 0/ 0
Channel 225 : 0/ 0/ 0
Channel 229 : 0/ 0/ 0
Channel 233 : 0/ 0/ 0
Load Information
Load Profile : Passed
Receive Utilization : 0%
Transmit Utilization : 1%
Channel Utilization : 2%
Attached Clients : 0 clients
Coverage Information
Coverage Profile : Passed
Failed Clients : 0 clients
Client Signal Strengths
RSSI -100 dBm : 0 clients
RSSI -92 dBm : 0 clients
RSSI -84 dBm : 0 clients
RSSI -76 dBm : 0 clients
RSSI -68 dBm : 0 clients
RSSI -60 dBm : 0 clients
RSSI -52 dBm : 0 clients
Client Signal to Noise Ratios
SNR 0 dB : 0 clients
SNR 5 dB : 0 clients
SNR 10 dB : 0 clients
SNR 15 dB : 0 clients
SNR 20 dB : 0 clients
SNR 25 dB : 0 clients
SNR 30 dB : 0 clients
SNR 35 dB : 0 clients
SNR 40 dB : 0 clients
SNR 45 dB : 0 clients
Nearby APs
AP 7411.b2d8.2e07 slot 2 : -81 dBm on ( 21, 160 MHz) (192.168.128.64)
AP 7411.b2d8.2dc7 slot 2 : -86 dBm on (101, 160 MHz) (192.168.128.64)
AP 7411.b2d8.37a7 slot 2 : -90 dBm on ( 53, 160 MHz) (192.168.128.64)
Radar Information
Channel changes due to radar :
DFS Statistics with Cisco Integrated RF ASIC
Filtered events on serving radio :
Filtered events on Cisco Integrated RF ASIC :
Triggered radar events :
DFS statistics last updated : seconds ago
Channel Assignment Information via DCA
Current Channel Average Energy : -106 dBm
Previous Channel Average Energy : -106 dBm
Channel Change Count : 0
Last Channel Change Time : 01/20/2024 22:36:53
Recommended Best Channel : 197
RF Parameter Recommendations
Power Level : 1
RTS/CTS Threshold : 2347
Antenna Pattern : 0
Persistent Interference Devices
Class Type Channel DC (%%) RSSI (dBm) Last Update Time
All third party trademarks are the property of their respective owners.
Number of Slots : 3
AP Name : Lori
MAC Address : 7411.b2d8.2dc0
Ethernet MAC Address : 149f.430d.1a70
Slot ID : 2
Subband Type : All
Noise Information
Channel 1 : -99 dBm
Channel 5 : -100 dBm
Channel 9 : -100 dBm
Channel 13 : -100 dBm
Channel 21 : -100 dBm
Channel 33 : -100 dBm
Channel 45 : -99 dBm
Channel 53 : -99 dBm
Channel 57 : -99 dBm
Channel 61 : -100 dBm
Channel 65 : -100 dBm
Channel 69 : -100 dBm
Channel 73 : -100 dBm
Channel 77 : -100 dBm
Channel 81 : -100 dBm
Channel 85 : -99 dBm
Channel 89 : -99 dBm
Channel 93 : -100 dBm
Channel 97 : -100 dBm
Channel 101 : -100 dBm
Channel 105 : -100 dBm
Channel 109 : -100 dBm
Channel 113 : -100 dBm
Channel 117 : -100 dBm
Channel 121 : -100 dBm
Channel 125 : -100 dBm
Channel 129 : -100 dBm
Channel 133 : -100 dBm
Channel 137 : -100 dBm
Channel 141 : -100 dBm
Channel 145 : -100 dBm
Channel 149 : -100 dBm
Channel 153 : -100 dBm
Channel 157 : -100 dBm
Channel 161 : -100 dBm
Channel 165 : -100 dBm
Channel 169 : -100 dBm
Channel 173 : -100 dBm
Channel 177 : -100 dBm
Channel 181 : -100 dBm
Channel 185 : -100 dBm
Channel 189 : -100 dBm
Channel 193 : -100 dBm
Channel 197 : -100 dBm
Channel 201 : -100 dBm
Channel 205 : -100 dBm
Channel 209 : -100 dBm
Channel 213 : -100 dBm
Channel 217 : -100 dBm
Channel 221 : -100 dBm
Channel 225 : -100 dBm
Channel 229 : -100 dBm
Channel 233 : -100 dBm
Channel 1 : -128 dBm @ 0% busy
Channel 5 : -128 dBm @ 0% busy
Channel 9 : -128 dBm @ 0% busy
Channel 13 : -128 dBm @ 0% busy
Channel 17 : -128 dBm @ 0% busy
Channel 21 : -128 dBm @ 0% busy
Channel 25 : -128 dBm @ 0% busy
Channel 29 : -128 dBm @ 0% busy
Channel 33 : -128 dBm @ 0% busy
Channel 37 : -128 dBm @ 0% busy
Channel 41 : -128 dBm @ 0% busy
Channel 49 : -128 dBm @ 0% busy
Channel 53 : -128 dBm @ 0% busy
Channel 57 : -128 dBm @ 0% busy
Channel 61 : -128 dBm @ 0% busy
Channel 65 : -128 dBm @ 0% busy
Channel 69 : -128 dBm @ 0% busy
Channel 73 : -128 dBm @ 0% busy
Channel 77 : -128 dBm @ 0% busy
Channel 81 : -128 dBm @ 0% busy
Channel 85 : -128 dBm @ 1% busy
Channel 89 : -128 dBm @ 0% busy
Channel 93 : -128 dBm @ 0% busy
Channel 97 : -128 dBm @ 0% busy
Channel 101 : -128 dBm @ 0% busy
Channel 105 : -128 dBm @ 0% busy
Channel 109 : -128 dBm @ 0% busy
Channel 113 : -128 dBm @ 0% busy
Channel 121 : -128 dBm @ 0% busy
Channel 125 : -128 dBm @ 0% busy
Channel 129 : -128 dBm @ 0% busy
Channel 133 : -128 dBm @ 0% busy
Channel 137 : -128 dBm @ 0% busy
Channel 141 : -128 dBm @ 0% busy
Channel 145 : -128 dBm @ 0% busy
Channel 153 : -128 dBm @ 0% busy
Channel 157 : -128 dBm @ 0% busy
Channel 161 : -128 dBm @ 0% busy
Channel 165 : -128 dBm @ 0% busy
Channel 169 : -128 dBm @ 0% busy
Channel 173 : -128 dBm @ 0% busy
Channel 177 : -128 dBm @ 0% busy
Channel 181 : -128 dBm @ 0% busy
Channel 185 : -128 dBm @ 0% busy
Channel 225 : -128 dBm @ 0% busy
Channel 233 : -128 dBm @ 0% busy
Channel 1 : 0/ 0/ 0
Channel 5 : 0/ 0/ 0
Channel 9 : 0/ 0/ 0
Load Information
Nearby APs
AP 7411.b2d8.37a7 slot 2 : -69 dBm on ( 53, 160 MHz) (192.168.128.64)
AP 7411.b2d8.2e07 slot 2 : -74 dBm on ( 21, 160 MHz) (192.168.128.64)
AP 7411.b2aa.7c67 slot 2 : -82 dBm on (197, 160 MHz) (192.168.128.64)
Radar Information
Channel Change Count : 1
Last Channel Change Time : 01/20/2024 00:11:59
Recommended Best Channel : 101
Power Level : 1
Antenna Pattern : 0
Number of Slots : 3
AP Name : Basement
MAC Address : 7411.b2d8.2e00
Ethernet MAC Address : 149f.430d.1a90
Slot ID : 2
Subband Type : All
Noise Information
Channel 1 : -102 dBm
Channel 5 : -102 dBm
Channel 9 : -102 dBm
Channel 17 : -101 dBm
Channel 25 : -101 dBm
Channel 29 : -101 dBm
Channel 37 : -101 dBm
Channel 41 : -101 dBm
Channel 45 : -101 dBm
Channel 49 : -101 dBm
Channel 53 : -101 dBm
Channel 73 : -102 dBm
Channel 77 : -102 dBm
Channel 81 : -102 dBm
Channel 85 : -102 dBm
Channel 89 : -102 dBm
Channel 93 : -102 dBm
Channel 97 : -102 dBm
Channel 101 : -102 dBm
Channel 105 : -102 dBm
Channel 109 : -102 dBm
Channel 113 : -102 dBm
Channel 117 : -102 dBm
Channel 121 : -102 dBm
Channel 125 : -102 dBm
Channel 129 : -102 dBm
Channel 133 : -102 dBm
Channel 137 : -102 dBm
Channel 141 : -102 dBm
Channel 145 : -102 dBm
Channel 149 : -102 dBm
Channel 153 : -102 dBm
Channel 157 : -102 dBm
Channel 161 : -102 dBm
Channel 165 : -102 dBm
Channel 169 : -102 dBm
Channel 173 : -102 dBm
Channel 177 : -102 dBm
Channel 181 : -102 dBm
Channel 185 : -102 dBm
Channel 189 : -102 dBm
Channel 193 : -102 dBm
Channel 197 : -102 dBm
Channel 201 : -102 dBm
Channel 205 : -102 dBm
Channel 209 : -102 dBm
Channel 213 : -102 dBm
Channel 217 : -102 dBm
Channel 221 : -102 dBm
Channel 225 : -102 dBm
Channel 229 : -102 dBm
Channel 233 : -102 dBm
Channel 45 : -128 dBm @ 1% busy
Channel 49 : -128 dBm @ 3% busy
Channel 73 : -128 dBm @ 2% busy
Channel 85 : -128 dBm @ 0% busy
Channel 93 : -128 dBm @ 2% busy
Channel 125 : -128 dBm @ 1% busy
Channel 129 : -128 dBm @ 2% busy
Channel 133 : -128 dBm @ 1% busy
Channel 137 : -128 dBm @ 2% busy
Channel 141 : -128 dBm @ 2% busy
Channel 193 : -128 dBm @ 2% busy
Channel 201 : -128 dBm @ 1% busy
Channel 221 : -128 dBm @ 2% busy
Channel 233 : -128 dBm @ 1% busy
Channel 1 : 0/ 0/ 0
Channel 5 : 0/ 0/ 0
Channel 9 : 0/ 0/ 0
Load Information
Attached Clients : 1 clients
RSSI -60 dBm : 1 clients
SNR 30 dB : 1 clients
Nearby APs
AP 7411.b2d8.37a7 slot 2 : -70 dBm on ( 53, 160 MHz) (192.168.128.64)
AP 7411.b2aa.7c67 slot 2 : -71 dBm on (197, 160 MHz) (192.168.128.64)
AP 7411.b2d8.2dc7 slot 2 : -75 dBm on (101, 160 MHz) (192.168.128.64)
Radar Information
Last Channel Change Time : 01/19/2024 19:31:13
Recommended Best Channel : 21
Power Level : 1
Antenna Pattern : 0
Number of Slots : 3
AP Name : Bedroom
MAC Address : 7411.b2d8.37a0
Ethernet MAC Address : 149f.430d.1f60
Slot ID : 2
Subband Type : All
Noise Information
Channel 1 : -100 dBm
Channel 5 : -128 dBm @ 2% busy
Channel 13 : -128 dBm @ 2% busy
Channel 29 : -128 dBm @ 2% busy
Channel 65 : -128 dBm @ 1% busy
Channel 73 : -128 dBm @ 1% busy
Channel 89 : -128 dBm @ 1% busy
Channel 101 : -128 dBm @ 1% busy
Channel 105 : -128 dBm @ 2% busy
Channel 109 : -128 dBm @ 1% busy
Channel 117 : -128 dBm @ 2% busy
Channel 121 : -128 dBm @ 2% busy
Channel 153 : -128 dBm @ 2% busy
Channel 157 : -128 dBm @ 2% busy
Channel 161 : -128 dBm @ 1% busy
Channel 173 : -128 dBm @ 1% busy
Channel 189 : -128 dBm @ 1% busy
Channel 197 : -128 dBm @ 2% busy
Channel 225 : -128 dBm @ 1% busy
Channel 1 : 0/ 0/ 0
Channel 5 : 0/ 0/ 0
Channel 9 : 0/ 0/ 0
Load Information
Nearby APs
AP 7411.b2d8.2e07 slot 2 : -71 dBm on ( 21, 160 MHz) (192.168.128.64)
AP 7411.b2aa.7c67 slot 2 : -84 dBm on (197, 160 MHz) (192.168.128.64)
Radar Information
Last Channel Change Time : 01/19/2024 19:30:46
Recommended Best Channel : 53
Power Level : 1
Antenna Pattern : 0
Put more APs.
Looks like I will need to add more APs to this project.  Seems crazy that 4 APs cannot cover 1300 sq ft.
That's why the recommended best practice is to perform a virtual WLAN survey or a physical one.
Radio transmission depend on the power used to feed the radios, but the transmited signal strength is reduced by any obstacle such as but not limited to office walls from different materials that absorb signal by Nth factor, croud, physical obstacles on the path from AP to clients, or even unwanted rebounds on the radio waves that redirect all energy to an unwanted direction, ...
With as well as 5Ghz works in the same environment, and this being my first 6GHz installation, I serious wonder if it is even worth it for the minor increase in performance.
