8.2MR4 Interim build availability
Javier Contreras
Release 8.2.131.x (82MR4)
The Interim Build process is over, the final 8.2.141.0 code is now posted in CCO
Thanks for your interest!
8.2.131.56
CSCva20321
Radio go stop-on-failure and the LAP cannot re-join to WLC for a while
CSCvb18339
DTLS connection failed because max control dtls connections reached
CSCvc10919
WLC Loaded EoGRE pulls CAPWAP traffic under slow path,brings dwn perf
CSCvb68541
AP1850 AP crash radio firmware crashed at 0x00990C98,
CSCuz15637
Aggregation not working with 1852 and Intel 7265
CSCvc07374
28/3800: - AP Radio down due to Cleanair off channel stuck
CSCvb47025
AP1832I : Beacons stuck
CSCva02176
COS AP sends Deauth frame instead of Disassoc for Disassoc Imminent
CSCvb55993
COS AP: Switching SSID on same AP fails due to AP sending INTER_VAP_ROAM, so WLC delayed by 10 sec
CSCvc17019
28/3800: Rx hang on radio 1 in 8.2.131.40
CSCvb32659
Syslog message  for  DP_BUFFER_POOL_EARLY_WARNING
CSCvc20813
28/3800: 8.2 MR4 - After trying config change on the WLAN, clients not able to join some APs
CSCvb90308
Continuous message on ap console: wlChkAdapter FALSE regval = ffffffff
CSCvc05515
3802 AP - crashes in flex or local mode oom-killer: gfp_mask=0x2040d0, order=0, oom_score_adj=0
CSCva65643
WLC reports Load Profile failed but clients connected under threshold
CSCvc19125
AP1810 radio crash @0x9433A0 in 8.2.130.0, QCA 2689921
CSCvb89745
1810 AP radio failure (firmware crashed)
CSCvc24165
AP crash due to kernel panic at mhsm_transition
CSCvc22291
8.2 MR4 - WLC keeping some Barbados in 20 Mhz when 40 Mhz is selected in the RF profile
Resolved Caveats 8.2.131.40
CSCvc07159
2800/3800 low throughput in 40MHz as Assoc response is sent at 20MHz
CSCvc01923
2800/3800: RTS frames sent at hardcoded 6 Mbps instead of minimum mandatory rate
CSCvb67909
2800/3800: unable to boot kernel if connect to C3560CX switch
CSCvb96077
2800/3800 - AP sometimes does not send Auth response.
CSCvb55698
2800 - Rxhang for 2.4 Ghz
CSCvb90324
1800 AP ssh disabled after few mode changes
CSCvb35018
Wism 2 crashes with task mdnsHATask
CSCvb35815
High CPU in 2504 with directly connected AP on upgrade to 8.2/8.3
CSCvb72084
8.2.121.11/8.2.124.15 : Unexpected reload: fatal condition at broffu_fp_dapi_cmd.c
CSCva02176
1800/2800/3800 AP sends Deauth frame instead of Disassoc for Disassoc Imminent
CSCvb89745
1810 AP radio failure (firmware crashed) [02]:0x009A46D9, QCA 02674060
CSCvb91826
1810W watchdog reset wcpd 8.2.130.0
CSCvb97562
2800/3800: IP Reassembler failing for fragmented packets causing connectivity failures
CSCvb38831
AP702w Crash - Multicast receive path
CSCvb75564
1852 beconing at 6M when its disabled, lowest mandatory rate is 12M, QCA 02675818
CSCvb75590
Radio1 FW Crash on 1810W AP @0x009A477D
CSCvb91881
2800/3800 APs deauthenticating(class3) the connected clients
CSCux21803
client not receive broadcast ARP request after AP failover
CSCva12055
Link down after reboot on 8540/5520
CSCva35509
rates reported incorrectly in 1572 MA/RAP deployment
CSCva56521
1600 AP False DFS detection
CSCvb38912
Flex ACL does NOT get applied when client roams in 'CENTRAL_WEB_AUTH'
CSCvb53368
validate rogue clients against AAA not work
CSCvb56598
Client associating to flexconnect WLAN recieve irrelevant VLAN's ARP
CSCvb65706
AP stuck in crash loop due to "AP image integrity check FAILED!"
CSCvb83097
1800/2800/3800 AP does not apply the 802.1p tag
CSCvb90247
8.3 Mallorca/1800: Multicast to multicast video stream is bad
CSCva65826
Wireless LAN Controller reboots unexpectedly
CSCvb59734
AP sending incorrect information about ciphers configured in WLAN
CSCvb64912
Packet retries command gets changed after reboot in 1532AP
CSCvb30105
1852 - capwapd crashes due to DTLS segmentation error
CSCvb75093
2800/3800: Measured TX Power out doesn't exceed 6 dBm per-path
CSCvb86711
2800/3800: Kernel Panic 8.2.131.18 - PC is at eth_type_trans
CSCvb34951
WLC not sending AP up/down trap
CSCvb44311
Dublefree posibly frm click[ME_2K:PC is at consme_skb+0x14/0x140]
CSCvb60500
2800 : memory corruption, SKB_Consume Kernel panic crash
CSCvb82735
2800 : Internal ap crashed at ZN16CapwapFragmenter14frag_iter_openEP1PRNS
CSCvb12066
Flex - VLAN support does not get automatically added
CSCvb49111
2800/3800: Kernel panic crash related to MVL radio stats in 8.2.124.15
CSCvb71964
AP1810W Crash, Radio Firmware assert @0x000CEBB1 and 0x00980AB2, QCA 02657120
CSCvb73540
1810 -FW crashed on Radio 0 @0x0098E38C, QCA 02658721
CSCvb82264
AP1552C Radio disabled due to beacon stuck /w stop-on-fail
CSCvb87315
2800/3800 - ERP IE is missing in Beacons for 802.11g only SSID.
CSCva90980
EoGRE high Ping latency/SNMP polling fails
CSCvb78906
Invalid logs about "Subnet mismatches while registering IP address"
CSCvb83517
1810W LAN Ports Not Forwarding IGMPv2 Traffic
CSCvb50962
2800/3800 AP radio interface dropping wireless client data traffic
CSCvb59058
1850: DFS Falses in ETSI domain 40/80 MHz
CSCvb67633
3800 AP upstream issue with 80Mhz data rates with WGB clients
CSCvb71494
APs 3800-2800 ICMP test failing
CSCvb62478
Wlan is allowed to be enabled when FT enabled without FT-psk/FT-802.1x
CSCvb73540
CSCvb54036
AP_3800 : Beacons stuck
CSCvb70134
AP1810W Radio firmware crash [02] 0x0098160C, QCA 02653531
CSCvb71797
AP1810W Radio Firmware Crash [02]:0x00989C62, QCA 02653521
CSCvb73404
AP1810W Radio firmware crash [02] 0x009807D9, QCA 02655868
CSCvb73745
2800/3800: wcpd crash in wcp mvl driver.
CSCuy70039
WLC should not forward DHCPINFORM when client is in DHCP_REQD
CSCuz17680
WLC crashed after enabling the enhanced client traps
Resolved Caveats 8.2.131.18
CSCvb54036
2800/3800 : Beacons stuck
CSCvb70134
CSCvb71797
CSCvb73404
CSCvb73745
CSCuy84275
Issue with wifi-calling & ms-services recognition with PP15 with Engin23
CSCvb60972
ME - Channel & width couldn't change from GUI
CSCuz45296
WLC sends acct-update multiple times in the same millisecond
CSCvb02472
Controller crash on radiusTransportThread, memory corruption
CSCuz94683
2800/3800 NSS API failures during overnight run
CSCva27809
1850 reboot when joining the wlc from standalone mode(VAP start failure)
CSCva91922
1800/2800/3800 - POE status on WLC shows Power injector when powered via POE.
CSCvb55698
CSCvb71928
crash during loading flexconnect config
CSCuw97966
10G Link down after reboot on WLC8510 on Nexus 5k
CSCuz89745
HA has continuous crash with Taskname: iappSocketTask
CSCva36161
1600 series AP crash after client trying to connect to disabled SSID
CSCva63310
Unable to enable mode Trunk on Mesh mode AP with WLC 8.2 code
CSCvb61259
AP 8.2 MR3 - 2800/3800 AP sending incorrect Flex AID causing client disconnect
CSCva30302
8.1 Mesh Aps crash when you add allowed VLANs to the MAP.
CSCuz84473
CAP3600 AP: clients join with AP in admin down state
CSCuz74051
ME: WGB associate failed with IOS AP
CSCvb29483
SNMP traps are not sent to the receiver
CSCuz71319
7500 crash when browsing Flex AVC stats
CSCvb21385
Compatibility issues with Internet Explorer 11 and WLC New GUI
CSCvb13455
sub._apple-mobdev2._tcp.local is not snooped by controller
CSCvb33101
702w Ethernet stop passing traffic.
CSCva76982
Need a command to disable DFS Blacklist Time Doubling
New Command added:
(5500-1) >config 802.11h smart-dfs ?
enable Enable non occupancy time doubling for Radar interfere channel.
disable Disable non occupancy time doubling and use legacy time (30 mins) for Radar interference channel.
Default state: enabled
Use disable to match legacy DFS behavior
CSCuz97248
ME - Client unable to ping default gw after getting IP
CSCva92053
2800/3800 - Kernel Crash :- because of Kmalloc called with GFP_KERNEL Flag
CSCvb43169
2800/3800 - Not doing soft reset if Radar is Detected with in CAC period.
CSCva85198
ME/1810 CAPWAP DTLS Teardown State after Image Upgrade
CSCva83393
2800/3800 - AP Crash and Console goes into hung state
CSCvb36119
3800 AP doesn't do 80Mhz data rates with WGB clients
CSCvb65617
Cleanair Slot 1 down events in 3800 AP
CSCvb35053
2802E AP crashes due to: kernel panic
CSCvb22629
3802 AP longevity radio stop/start test causes BUG:spinlock lockup
CSCvb02220
2800/3800- Clients get IP via mgmt intf instead of dynamic intf
CSCvb58173
2800/3800 watchdog reset due to gateway
CSCvb06740
2800/3800: show version missing bootloader version
CSCva66595
2800/3800: New bootloader auto-upgrade
CSCvb18565
2800/3800 Delay Forwarding Packets from Radio to LAN
CSCvb64452
1800/2800/3800 - DTLS not tear down when PWRINJ failure
CSCvb33406
2800/3800: crash due to wcpd in 8.2.121.14
CSCvb25999
2800/3800 RF domain name parse error
CSCvb33401
2800/3800: Kernel panic crash in 8.2.121.14
CSCva27977
2800/3800 On flex mode Multicast not working for fresh wlans.
CSCvb38281
2800/3800 does not allow printer traffic after association
CSCvb33575
2800/3800 AP not sending auth response as DS pkt is dropped in driver
CSCvb66659
2800/3800 NSS table gets full denying new clients to associate
10 Replies 10
patoberli
Hi, I'm not sure I understand the new DFS function correct.
Disable Disable non occupancy time doubling and use legacy time (30 mins) for Radar interference channel.
Does this mean, on the old code it will not re-use the channel for 30 minutes, while on the new release that time doubles by default to 60 minutes?
Correct. On releases 8.1 and lower, the channel was blocked for reuse for 30 min, as per DFS regulatory requirements
on releases 8.2 and higher, if the channel gets repeated DFS triggers, it will be blocked longer, to avoid using it on DCA channel assignament
With this command, you can disable the new behavior, and the WLC will work as in 8.1 DFS mechanism
regards
Thanks. I would suggest to slightly rewrite the help text (if that is a copy of it) to show the 60 and 30 minutes.
ivanchakarov
Level 3
Level 3
Any news about the release date?
HI Ivan
we are in final code verification, with a release date set between Dec 7th and 12th
regards
Thank you for the information!
patoberli
It seems the final release is already out: http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr4.html
Andy Chew
Community Member
Hi Javier,
Does this release includes the ME for 2802i? if not, when will it be released ?
Thanks alot
Andy
Hi Andy
ME for 2800/3800 is a feature of 8.3,  not part of 8.2 version
regards
