8.3MR1 Beta availability
Javier Contreras
Release 8.3.104.x Beta (8.3MR1)
The beta process is over, the code is now posted as 8.3.111.0 in CCO, thanks for your participation!
Final Post now in CCO, 8.3.111.0
This release adds the following functionality:
  • TKIP  support for 1800/2800/3800
  • 1560 AP
  • Apple features in 1800/2800/3800
8.3.104.131
CSCuz15637
Aggregation not working with 1852 and Intel 7265
CSCuz40066
Guest Anchor:Foreign to Foreign roam fails on GA scenario
CSCuz50774
WLC lossing pings to itlsef Reaper cleaning up exited task osapi_ping_rx
CSCuz67292
Client not moving to RUN state after CAS perform posturing on client
CSCva03376
UX-AP3702i After primed carrier set 5GHz only allowing four UNII3 ch
CSCva22440
3800: QBSS STA Count keeps incrementing with STA associating again
CSCva28211
AireOS UX AP : 'JP' should be used as world mode in Beacon/Probe Res
CSCva28524
WLC 8.3 - Creating SNMP community fails
CSCva31178
AP: 8.3 - Radio reset due to offchannel stuck
CSCva32411
Clients losing connectivity when reauth with DOT1X over 702w AP
CSCva52825
2800/3800 does not do PMTU discovery during join/image download
CSCva65643
WLC reports Load Profile failed but clients connected under threshold
CSCva74487
8540 crash on running show commands task :emWeb
CSCva85667
Clients get TKIP MIC from 2702AP  due to receiving the broadcast IPX
CSCva95251
DSCP traffic is not limited to maximum QoS Profile value
CSCvb09381
Unable to add or modify SNMP strings on a 5520 HA Pair running 8.1.122.0
CSCvb25233
Enable VLAN-RLAN Mapping in FlexConnect Group
CSCvb28231
Controller crashed due to memory corruption
CSCvb35018
Wism 2 crashes with task mdnsHATask
CSCvb44169
emWeb reaper reset after "clear mdns service-database all"
CSCvb48603
Evaluation of wlc for Openssl September 2016
CSCvb49804
AP not forward frames to some STAs under high traffic
CSCvb54166
Malformed 11v element on HSR WGB with WLC 8.2+
CSCvb66080
VLAN override from ISE is not working for RLAN with FlexConnect Local Switching
CSCvb68541
AP1850 AP crash radio failure (firmware crashed) at 0x00990C98
CSCvb71168
RSA256-AES256 dtls encryption lowers PMTU but AP doesnt' respect it
CSCvb78522
5520 HA Active reloads stating "Reason: Self Sanity Check Failed"
CSCvb80511
CWA is not working for flex-bridge APs pointing ACL rx from Radius doesn't exist
CSCvb81359
WLC 8540 HA. RMI ping and access to standby fail when using non-default ap-manager
CSCvb85576
Evaluation of wlc for CVE-2016-5195 (DIRTY CoW)
CSCvb91603
Data rate in the 5GHz cannot be locked to 6Mbps for 1810AP
CSCvb92562
Evaluation of all for Openssl 1.0.1 September 2016
CSCvb94610
Restore command to disable GARP
CSCvb94697
2800/3800 11n macbook client has dropping connectivity while connecting to AP3800
CSCvb99768
AP2800 Kernel panic PC is at wlRecv+0x4c8/0x994 [ap8x]
CSCvc01563
3800: Cmd-timeout observed in 8.2 MR4
CSCvc08942
OpenSSL ssl3_read_bytes Function Denial of Service Vulnerability
CSCvc10813
1852 AP - radio FW crash @ 0x0099B21E
CSCvc13082
5Ghz radio crashed on 3800 AP due to RX-HANG Detected.
CSCvc13175
GLC-T SFP stopped working in CT5520 (1G Port down on 5520)
CSCvc14508
3800  AP crash with watchdog reset on 8.2.130.0
CSCvc16755
AP3802 custom power level not initialized after reboot
CSCvc18275
Trial SSL certificate: Error received "The CSR must include a Country code"
CSCvc18291
AP1810 crashed @0x0098083D  (CSU1+SBA3)
CSCvc19125
AP1810 radio crash @0x9433A0 in 8.2.130.0
CSCvc23658
Clients not removed from flexconnect and capwap in APs flexconnect central-sw
CSCvc25669
rfidTask is causing a high CPU on the WLC
CSCvc25837
DP crash on 5508  setup while running longevity on 3rd day with 8.2.131.45 load
CSCvc26901
optimized Roam Failed with AP model -1852
CSCvc31304
83MR1: AP syslog flood for TLV-DEC-ERR: cannot process TLV for TLV_DMS_CLIENT_REQUEST_PAYLOAD(325/0)
CSCvc32339
AP falls into u-boot mode under normal operation
CSCvc32706
3800 APs: Not seeing all COS neighbors
CSCvc32856
3800: Sends a AQ Event as soon as RRM changes channel causing bad channel selection and changes
CSCvc33258
WLC: Unable to config RX-SOP threshold for IW3702 AP
CSCvc35318
792x roaming between APs in ME takes ~10 seconds
CSCvc38214
2800/3800 Sending Acks to client at 54 data rate although Basic rate is 12 & 24
CSCvc39622
ME disable AVC and HTTP profiling by default
CSCvc39963
3800 : FRA revert command failing to revert XOR to 2.4GHz
CSCvc40470
AP radio hang chatter: wl0: rxRingStuckDetect(271): RX-HANG Detected!!
CSCvc40564
TPC - Maximum/Minimum power level are not set as expected
CSCvc41300
2800/3800/1562 doesnt advertise k9w8 in the CDP TLV breaking Auto Smart Port integration
CSCvc42741
AP3800/AP2800 : Failed to receive data keepalive and  Process capwapd gone
CSCvc42939
3800 AP duplicating multicast packets
CSCvc43232
2800/3800 uses 11n data rates to send data packets to 11b only clients failing to assoc
CSCvc43328
2800/3800 Sending Acks to client at 54 data rate although Basic rate is 12 & 24 in 8.2Mr4Esc
CSCvc44581
3802 AP - crashes PC is at wlxmit+0x8ec/0x123c [ap8x]
CSCvc45038
2800/3800 Beacon drift 25ms with offchannel/cleanair scanning @3sec mc9060 client drops
CSCvc48232
AP crash due to kernel panic at mhsm_transition
CSCvc50228
2800/3800 Sending Data packets to the 11g clients sometimes with messed up data rates
CSCvc52004
iOS device connect to the dot1x network slowly
CSCvc53578
2800/3800 11b only clients does not associate if HT is disabled
CSCvc53675
1852 AP - kernel backtrace at ol_ath_tx_mgmt_wmi_send+0x0/0x1e4
CSCvc60233
3800: Off-channel timeout is observed
CSCvc69564
AP_1852E : Multiple Beacons Stuck
CSCvc74695
XOR radio pushes local-mode AP config for flex-mode AP causing Client disconnect
CSCvc76148
2800/3800 Beacon drift causing mc9060 client drops
CSCvc84677
8.2MR5: AP1850 HT/VHT IE missing when WLAN in mixed mode
8.3.104.95
CSCvb78906
Invalid logs about "Subnet mismatches while registering IP address"
CSCvb94697
CSCvb90405
OEAP firewall port forwarding not working
CSCvc07374
2800/3800 - AP Radio down due to Cleanair off channel stuck
CSCva20321
Radio go stop-on-failure and the LAP cannot re-join to WLC for a while
CSCvb38831
AP702w Crash - Multicast receive path
CSCvb64912
Packet retries command gets changed after reboot in 1532AP
CSCvb65706
AP stuck in crash loop due to "AP image integrity check FAILED!"
CSCvc11544
Default Neighbor Pruning Timer need to be increased to keep neighbor entries for 1 hour
CSCvc17019
Barbados: Rx hang on radio 1 in 8.2.131.40
CSCva65826
Wireless LAN Controller reboots unexpectedly
CSCvb35815
High CPU in 2504 with directly connected AP on upgrade to 8.2/8.3
CSCvb52310
Silent Boot on 2800/3800
CSCva02176
COS AP sends Deauth frame instead of Disassoc for Disassoc Imminent
CSCvb32659
Syslog message  for  DP_BUFFER_POOL_EARLY_WARNING
CSCvb59734
AP sending incorrect information about ciphers configured in WLAN
CSCva81409
Clients stuck in WEBAUTH_REQD state, emweb form cannot be submitted
CSCvb90793
AP name unknown in SNMP bsnDot11StationDeauthenticate traps
CSCvc22291
8.2 MR4 - WLC keeping some Barbados in 20 Mhz when 40 Mhz is selected in the RF profile
CSCvc18562
AP fail to auto reboot after migration to ME
CSCvb97775
AP3802 crash watchdog reset(capwapd)
CSCvc12513
DBS max width is not working; DCA width is not getting applied to all 3800 APs
CSCvc12703
1810W LAN Port 2 maps to wrong VLAN on N+1 failover to Primary
CSCvc30561
COS AP's clients cannot subscribe to multicast stream after a while
CSCvc23063
8.3MR, 8.2MR4: Corsica does not detect Aero Scout RFID tag
CSCvb94436
TKIP support for 1800 series APs
Resolved Caveats 8.3.104.82
CSCvb56598
Client associating to flexconnect WLAN recieve irrelevant VLAN's ARP
CSCuz85820
Mobility Express: Unable to disable web-auth secure web in 1850
CSCvb38912
Flex ACL does NOT get applied when client roams in 'CENTRAL_WEB_AUTH'
CSCvc07159
2800/3800 low throughput in 40MHz as Assoc response is sent at 20MHz
CSCvb89745
1810 AP radio failure (firmware crashed) [02]:0x009A46D9, QCA 02674060
CSCvb75590
Radio1 FW Crash on 1810W AP @0x009A477D with Build 8.3.104.54 QCA 02706236
CSCvb75564
1852 beconing at 6M when its disabled, lowest mandatory rate is 12M, QCA 02675818
CSCva35509
data rates reported incorrectly in 1572 MA/RAP deployment
CSCvc00337
OEAP: Not broadcasting VHT IE in 8.3.104.67
CSCvb91881
2800/3800 APs deauthenticating(class3) the connected clients on 8.2.131.18 randomly
CSCvb83097
1800/2800/3800 AP does not apply the 802.1p tag
Resolved Caveats 8.3.104.78
CSCvb86665
8.3MR clients unable to connect to TKIP ssid
CSCvb75093
AP3800 Measured TX Power out doesn't exceed 6 dBm
CSCvb73404
AP1810W Radio firmware crash [02] 0x009807D9, QCA 2655868
CSCvb30105
1852 - capwapd crashes due to DTLS segmentation error
CSCvb90247
8.3 Mallorca/Hydra: Multicast to multicast video
CSCvb94455
AP3800 sleeping function called from invalid
CSCva12055
Link down after reboot on 8540/5520
CSCvb55698
2800 - Rxhang for 2.4 Ghz
CSCvb97562
AP3800- IPReassembler problem causing connectivity failure
CSCvb94003
WLAN config updates not working thru webui with 8.4.1.110
CSCvb65617
Cleanair Slot 1 down events  in 3800 AP
CSCvb72084
.2.121.11/8.2.124.15 : Unexpected reload: fatal condition at broffu_fp_dapi_cmd.c
CSCvb90403
AP1800W: hardware watchdog reset at PC= 0xc03b3ffc
CSCvb71964
AP1810W Radio Firmware assert @0x000CEBB1
CSCvb73540
1810 -FW crashed on Radio 0 @0x0098E38C,
Resolved Caveats 8.3.104.70
CSCvb59734
CSCvb64869
Anomalous Interference/channel utilization observed in 8.3
CSCva82948
Barbados: LED cycling between RED-GREEN even after     client joined
CSCva91922
1800/2800/3800 - POE status on WLC shows Power injector     when powered via POE.
CSCvb61259
AP sending incorrect Flex AID causing client     disconnect
CSCva36161
1600 series AP crash after client trying to connect to disabled SSID
CSCuz74051
ME : WGB associate failed with  IOS AP
CSCva63310
Unable to enable mode Trunk on Mesh mode AP with WLC 8.2 code
CSCvb67415
ATF Optimization config didn't sync up when AP joined.
CSCvb55698
CSCvb54036
Beacons stuck during radio handover
CSCvb73745
Barbados wcpd crash due to radio stats
CSCvb77682
Barbados: ioctl error message when setting XOR to 5GH band
CSCvb75797
1810w AP-specific vlan override for RLAN not working ssid flexconnect vlan takes precedence
CSCvb71494
APs 3800-2800 ICMP test failing
CSCva27809
1850 reboot when joining the wlc from standalone mode(VAP start failure)
CSCvb13455
sub._apple-mobdev2._tcp.local is not snooped by controller
CSCvb34951
WLC not sending AP up/down trap
CSCvb73648
Corsica: kernel crash at ath_sysctl_pktlog_client_mac
CSCuw97966
10G Link down after reboot on WLC8510 on Nexus 5k
CSCuz45296
WLC sends acct-update multiple times in the same millisecond
CSCvb50962
Barbados AP radio interface dropping wireless client data traffic
CSCva50728
3800 does not set EOSP on last data packet for U-APSD
CSCvb73540
1810 -FW crashed on Radio 0 @0x0098E38C, QCA 02658721
CSCvb80775
Kernel Panic crash 8.3.104.59
CSCvb83517
1810W LAN Ports Not Forwarding IGMPv2 Traffic
CSCvb67633
3800 AP upstream issue with 80Mhz data rates with WGB clients
CSCvb85052
AP3800: PMF client gets stuck trying to associate to PMF WLAN
CSCvb31857
WLC rejects client association with 11k Assisted roaming 2800 dual 5G
CSCvb12066
Barbados Flex - VLAN support does not get     automatically added
CSCvb49111
Barbados: Kernel panic crash related to MVL radio
CSCvb86711
Kernel Panic 8.2.131.18 - PC is at eth_type_trans
CSCvb82735
ME_2800 : Internal ap crashed at ZN16CapwapFragmenter14frag_iter_openEP1PRNS
Resolved Caveats 8.3.104.61
CSCvb02220
Clients get IP via mgmt intf instead of dynamic intf
CSCva83234
3800 : Kernel Crash during image download
CSCvb14148
3800 AP not joining to WLC with D reg-domain
CSCvb61217
Workaround for CSCva81409 Clients stuck in WEBAUTH_REQD  state, emweb form cannot be submitted
CSCvb41738
AP1832I : Kernel Panic crash PC is at unmap_single_vma
CSCvb27528
Client assoc fails WPA+WPA2+tkip+aes+802.1x
CSCvb68637
show ble device-info all kicks user out of Cisco shell
CSCvb35173
3800: Radio crash, beacon stuck - due to lost   txq reference.
CSCvb71928
capwapd crash when loading Flexconnect config
CSCvb68960
1852 kernel panic @ at ieee80211_find_channel+0x2c
CSCvb72994
DHCP Leases not displaying on UI
CSCvb69810
1800: Kernel panic PC is atprint_bad_pte+0x170/0x190
CSCvb70191
8.3MR:Shutting unshutting wlan changes TKIP cipher to AES on 3800 for 8021x
Resolved Caveats 8.3.104.54:
CSCvb26415 Mobility Express: Unable to upgrade from 8.2.100.0 to
CSCvb36432 SSIDs vanishes from standalone AP after reboot
CSCvb44311 Dublefree posibly frm click [ME_2K:PC is at
CSCvb33666 OEAP1810 -  Crash due to DTLS
CSCuu98988 capwapv6 not doing dnsv6 query for CISCO-CAPWAP-CONTROLLER
CSCux84505 Downlink TCP traffic is dropped by AP
CSCus83638 [BZ1043] AP 5Ghz Radio Beaconing but not accepting Client Assoc.
CSCva41482 Autonomous AP does not forward ARP requests to client on tag VLAN
CSCvb49513 Failed to join after image Upgrade
CSCva82369 8.3.102.0 crash on applying custom rogue rule using GUI
CSCvb29483 SNMP traps are not sent to the receiver
CSCva33663 WLC 8510 crashes with task:emweb on changing Radio
CSCva27809 QCA based AP VAP start failure
CSCvb35053 2802E AP crashes due to: kernel panic
CSCvb49333 Barbados: Error message and delay while executing "undebug all"
CSCvb41738 AP1832I : Kernel Panic crash PC is at unmap_single_vma+0x324/0x5e4
CSCvb46865 5520 crashed with taskname: snmptask in 8.3.104.38
CSCvb37062 AP1852 Data-DTLS Not able to Establish After WLC Reboot
CSCvb36119 3800 AP doesn't do 80Mhz data rates with WGB clients
CSCvb04502 local mode AP responds to ARP req for client
CSCvb38281 3800 does not allow printer traffic after association
CSCvb23576  Excluded clients can connect to 2800 APs in Flexconnect local switching
CSCvb46639 FEW-AVC - HTTP protocol packets are not marked
CSCvb10545 AP F/W Not handling Non-QoS Data Frames from QoS STA
CSCvb60485 AP2800 : watchdog reset(wcpd no heartbeat)
CSCvb55993 Switching SSID on same AP fails due to APsending INTER_VAP_ROAM, so WLC delayed by 10 sec
CSCva99864 EAP-TLS fails with Windows and ME using "Smart card or certificate" auth
CSCvb21385 Compatibility issues with Internet Explorer 11 and WLC New GUI
CSCvb30663 CLient not associated with  EAP profile method eapfast
CSCvb18565 Delay Forwarding Packets from Radio to LAN
CSCvb58173 AP 3802i Crash: watchdog reset(gateway)
CSCvb64452
DTLS not tear down when PWRINJ failure
Resolved Caveats: 8.3.104.43:
CSCuy74931 AP1815/50: Overide 802.1x Supplicant Credentials lost after reboot
CSCuy92423 CWA broken in beta image 8.0.122.50
CSCuz22198 Slient reload on 5508 with %OSAPI-0-TIMER_CREATE_FAILED: timerlib.c
CSCuz29885 Flex AP automatically switching to non DCA channels
CSCuz46892 ME: external AP rebooted bec Detected another ME controller
CSCuz48289 FT-PSK PMF-Optional   EAPoL M2 MIC error on change to local auth-flex
CSCuz52435 Evaluation of wlc for OpenSSL May 2016
CSCuz54125 5500 SSHpmCert Memory Corruption( overrun) on Pmalloc/Pfree buffers
CSCuz65175 ME 1852 : HTTP profiling causes CPU spikes and degraded performance
CSCuz79869 8510 silent crash
CSCuz84473 CAP3600 AP: clients join with AP in admin down state
CSCuz90785 8.2MR1:Traffic black hole WEP errors on IW3702 WGB during roaming mesh
CSCuz96571 Ap-list new mobility packets flooding between AirOS WLC
CSCva11186 1852 AP - wcpd invoked oom-killer
CSCva11919 Loaded EoGRE pulls CAPWAP traffic under slow path
CSCva15190 WLC CCX client location calib shows low cLD11ClientCalibSamplesCollected
CSCva17231 on HA failure,  Active WLC RF group stuck on 'HA Standby' & RRM stopped
CSCva18981 WLC Crash 8.2.100
CSCva25760 GUI: setting static DNSv6 entries do not work
CSCva27711 FlexConnect: AP radio reset during FT when Central DHCP is enabled WLAN
CSCva27809 1850 reboot when joining the wlc from standalone mode(VAP start failure)
CSCva30926 11v BTM request should be sent  to client after dot1x finished
CSCva34071 802.11 Extended capabilities missing when returning to Connected Mode
CSCva34774 WLC crash at apfReceiveTaskwith reason System Crash
CSCva35576 Flex standalone AP changes channel  when reboots
CSCva38615 3800: Accounting record stuck on 3800 AP running 8.2.111.26
CSCva43142 3800: Cmd-timeout due to Rx-Hang
CSCva46486 5520 controller crash with no core or crash file written
CSCva47891 WLC Crash - At task 'EAP_Framework_0'
CSCva47999 AP2800: spectrum mgmt bit is off in beacon
CSCva49651 Flex Data DTLS enabled
CSCva50196 Memory corruption EAP for Mesh
CSCva51051 3800: Memory leak leading to NSS buffer alloc fail
CSCva53005 1810W port Sending assoc-resp with status denied rates when RF profile
CSCva55011 Task Name redXmlTransferMain crashed with HA SSO
CSCva57323 Make IW3702 UX product be primed in Pakistan
CSCva59741 ME: incorrect pop-up error while setting channel width for radio2(5GHz )
CSCva62427 3800: Tracebacks seen on WLC after bootup
CSCva65408 client not associated with EAP profile method peap and WLC crashed
CSCva66339 Flex AP's in standalone mode deauth client during EAPoL exchange
CSCva66468 3800: FW EU Hang Detect not working
CSCva66496 AP3802 Crash  Watchdog reset on capwapd
CSCva70708 AP 3802 8.3.102.0 radio crashes due to beacon stuck for for 120 sec
CSCva74500 Rxsop when set to custom goes to default when capwap restarts
CSCva74927 3800 Flex - AP disjoins with 'Failed to get ARP entry for WLC' error
CSCva76731 ME GUI does not show Localization language with Internet Explorer
CSCva77139 Increasing aaaDb max entries to 12000 for UCS platforms
CSCva78193 3800 AP client trace filter does not bundle debugs
CSCva78358 1810W RLAN VLAN local switch LAN mappings not applied on N+1 failover
CSCva80437 1810 : crash @ RlanClientTracker_udpate_tx_stats
CSCva81217 Edit of RF Profile settings via GUI resets RxSOP threshold Vaue to Auto
CSCva82324 AP sends incorrect Option 60 value in DHCP discover
CSCva83393 3800 Flex - AP Crash and Console goes into hung state
CSCva83884 WLC System crash on aaaQueueReader
CSCva85198 1810W  APs moved to CAPWAP DTLS Teardown State after Image Upgrade
CSCva86328 AP1830/1850: Failed client association on inter AP roam (SSID change)
CSCva86353 5508 WLC crash on 'apfMsConnTask_7' on 8.0.132.0 code.
CSCva87295 Flex AP radio reset during FT with Central dhcp and Nat-pat enabled
CSCva88059 Mesh AP crashing task name "Software Task crashed"
CSCva88923 2802 AP is going off channel and it is not acknowledging packets
CSCva89218 3800: turning on AP trace on console crashes AP
CSCva89698 WLC is leaking packets from virtual IP onto LAN
CSCva90259 1800/2800/3800 Flex - Roaming may cause clients to be stuck in 802.1x
CSCva90980 EoGRE high Ping latency/SNMP polling fails
CSCva92053 Kernel Crash :- because of Kmalloc called with GFP_KERNEL Flag
CSCva92615 Access Point antenna gain changes to 0dBi randomly
CSCva92900 Spartan:Ap Perfromance max config shows the value more than max cap
CSCva93401 WLC system crash (spamApTask) immediately after upgrade to 8.2.121.0
CSCva94183 2800/3800 -E domain APs only advertise EU country code no matter what
CSCva95037 AP Inventory issue - CiscoLwappApMib
CSCva95424 Spartan GUI: For All Clients AVC top application usage is 16KB
CSCva96879 1810 AP stops client assoc every 24-36 hrs
CSCva96899 WLC8510 crashes task "tplusTransportThread" when 8.2MR2 upgrade
CSCva98592 Unexpected reload: fatal condition at broffu_fp_dapi_cmd.c
CSCva98597 Emweb task stuck at 100% CPU usage
CSCvb00327 WISM2_5508 crashes in Process Bonjour_Process_Task
CSCvb02180 ARP table full. Unable to delete ARP mappingIP
CSCvb02472 Controller crash on radiusTransportThread
CSCvb03187 Maximum port range value cant able to set for http-proxy in WLC GUI
CSCvb03742 With AP in flex mode,  Ap leaking RA'S of native vlan
CSCvb06768 AP3800 Flex: Association Response is corrupted (malformed)
CSCvb10106 radio crash due to beacon stuck
CSCvb10579 Override VLAN is not working when VLAN is pushed from the AAA VLAN-ACL
CSCvb15774 702w AP crashed in Process: LWAPP REAP DHCP PROCESS
CSCvb18155 Milos/3800 11hpwrconstr (8BE0): Operation not supported console msg
CSCvb19729 WLC crash - Task name EAP_Framework_0
CSCvb20104 radio crash due to beacon stuck(TBTT Mask is disabled)
CSCvb20109 windows 10(intel 7260) client unable to join after DFS CAC expiry
CSCvb21304 Optional PMF OUI removed from beacon/probe responses
CSCvb21732 FlexConnect WLAN ordering AP radio reset on HA
CSCvb27236 Flex 3800 3K - ACL with deny ip/network is not working
CSCvb28734 kernel panic in extStaDb_RemoveAllNon11hStns()
CSCvb29843 Secondary ISE Server IP not sent to AP by WLC
CSCvb32842 ME- 1850 crashed with taskname emWeb
CSCvb33401 3800: Kernel panic crash in 8.2.121.14
CSCvb37768 AP2800 :  Heartbeat thread getting Dead  after changing Root AP channel
CSCvb38441 ME_2800 : Kernel Crash with PC is at 0x939c8400
CSCvb39266
WLC TACACS no longer functions in 8.2Mr3Beta
41 Replies 41
Hi Javier,
My client is having some issue with AP 2802 with the WLC. It will randomly disassociate with the WLC and would not join back. My current AP image is 8.3.102.0 ME. Can i try this beta release ?
Apologies that i click on the wrong reply button.
Thanks you very much
Best Regards,
Andy
Hi Andy
please send email with your CCO username to :wnbu-mrbeta@external.cisco.com
regards
posted in the wrong place, please delete
patrick.kofler
Level 5
Level 5
Hello Javier,
do you have an ETA on when the bug CSCvb71168 will be incorporated in on of the MR releases?
Best Regards,
Patrick
Hi Patrick
Currently CSCvb71168 is scheduled for 83MR2, to allow for additional testing to take place. if there is an urgency to re-evaluate this, please let me know the details by email
regards
kdavison007
Level 3
Level 3
Does this version add support for WiFi tag tracking for the 3802?  I'm most interested in making sure our Stanley WiFi RTLS tag tracking works up through our MSE.  It looks like this is not supported in production 8.3 because of limited CCX support?
I have tested Ekahau tags on 8.3.104.70 and 1800APs and they are not detected. 3700 Aps can detect the tags on the same code.
Also not sure if MSE supports location tracking for Wave 2 APs. You might need CMX.
Hi Brian,
1800 with tag are not working as of current beta code. Dev team is working on it
3800 has different implementation for this
regards
When you say 3800 has a different implementation does that mean that it is or will be supported or never will be supported?
hi
3800 is targeted as supported for 8.3MR1
regards
Javier,
Is the tag issue with the 3802 still being fixed in 8.3MR1? If so do you guys have a time frame for the release of MR1?
mte
Community Member
Hi Javier.
We have WLC 5520 and AP 2802i.
After upgrading to  8.3.104.70 some APs drop to approx. 6 Mbps with 5Ghz radio.
A AP reset fix the problem temporary, but the speed/data rate drops to approx. 6 Mbps again after a day or two.
Could this problem be related to this:
CSCvc07159 - 2800/3800 low throughput in 40MHz as Assoc response is sent at 20MHz
regards
OGB
Frequent Visitor
Frequent Visitor
Hi Javier!
My APs are now spamming logs like this:
*Dec 13 15:11:39.471: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:11:49.627: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:12:10.763: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:12:19.131: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:14:15.519: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:15:30.263: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:16:49.523: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:16:49.891: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:16:54.919: Received and decoded a DMS client request payload SUCCESSFULLY
*Dec 13 15:17:40.227: Received and decoded a DMS client request payload SUCCESSFULLY
Is this because this is a beta release? Also I've attached a traceback I see from time to time.
Flo
Hi Florian
nothing to worry about, it is unnecessary message, tracked in CSCvc49713
regards
Hi Javier,
I'm having an issue connecting on the service port with ssh. I am trying to connect to the ip from a switch in the same vlan. I can ping the service port ips on the primary and standby ok. I can also ssh from the same switch to other switches so I know there is nothing blocking ssh. I can ssh to the management ip address ok also.
I get a connection aborted error status 0 error  on one switch and a  no matching cipher error on a 7k.
I'm pretty sure this worked on 8.2.130
