802.11ac Wireless Bridging
andrewdours
Anybody bridging with 802.11ac?  What would I need to make this happen?
Sandeep Choudhary
HI,
Dont forget to check:
To get the higher rates you have to use WPA2/AES or Open/No Auth, and WMM has to be allowed.
Dont forget to rate helpful posts
Sounds like you've done this.  What I was really asking for was more of a high level.  Does Cisco have a specific model of AP that can perform 802.11ac wireless bridging?  Can it run autonomous or does it require a controller?  What types of antennas are available?
High level :)
I never used these product but still check these:
Did not find any official document abouts products for 802.11ac bridging ...
http://www.engadget.com/2012/06/26/cisco-rolls-its-first-linksys-802-11ac-wifi-router-and-bridge/
http://www.smallnetbuilder.com/wireless/wireless-news/31802-cisco-unveils-its-draft-80211ac-router-and-bridge
you better ask to nearest cisco supplier about this, they can help you more in this matter.
Hope this helps.
kaaftab
Level 4
Level 4
Here is the comparision sheet for all AP
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#indoor
and here is good link for mesh deployment and every thing is explained
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-mesh/111451-indoor-mesh-deploy-guide-00.html
