802.11ac with NAC with/without PSK
David Ritter
Level 4
Level 4
previously 802.11ac requires WMM and wpa2/aes psk for the client to achieve optimum performance.
so what happens when we use NAC/802.1x and leave off the PSK?
Sandeep Choudhary
You can still get 802.11ac rates ..
Must do: 802.1x WPA2/AES with WMM required and enabled 80Mhz channels.
Also check this posts: https://mrncciew.com/2014/01/10/802-11ac-with-cisco-3700-ap/
Dont forget to rate helpful posts
