11-18-2002 02:26 AM - edited 07-04-2021 08:21 AM
802.11B use DSSS and 802.11G will use OFDM so
will a client 11B be able to talk with a 11G client (hadoc mode)?
If a upgrade my AP 1200 or 1100 in order to support 11G will i still be able to talk
with 11B clients?
11-18-2002 11:24 AM
I believe everybody who says they will make 802.11g radio chipsets will make them backward compatible to 802.11b. So it should all work together. It will just be slower on 802.11b.
Boy won't this be fun. 802.11b, 802.11g, 802.1x and 802.1i all together on one Access Point. Of course some will also have 802.11a.
11-18-2002 01:41 PM
YES..802.11 G is backword compitible with 802.11b..But not with 802.11a.
11-18-2002 01:45 PM
I mean to say 802.11g "will be" backword compitible with 802.11b as 802.11g is not released yet by cisco..
02-14-2003 08:53 AM
And when does the g will be released bay cisco ?
11-23-2004 10:07 AM
HI,
Just thought I would answer this inquiry. Yes you can have a mix of clients in ad hoc mode as the A/B/G combo card (AIR-CB21AG and AIR-PI21AG) will just use the B radio speed/data rates and will have no problem talking with other B compliant clients device. Hope this helps.
Aaron
11-25-2004 12:19 AM
This works well. I have heard a lot of SE's out there that suggest "watch out for your performance". But you know, in my recent experience if you are deploying a purely G environment you will have little problems.
Just be aware that if you go G your effective radiation will drop because a greater portion of the spectrum is used.
I find that if I have one AP and maybe a half dozen users in the room, nobody notices. When you get maybe 20 users connected then your WLAN behavior changes and everyone pretty much runs at 'B' speeds.
Chris
