876W - Wireless communication problem...
asarida01
Community Member
I have a problem with the routing of packets from the dot11radio0.1 interface to vlan1 and then to modem/router. VLan 1 is configured with 'VLAN for routing' (that the opnion inside SDM). My Router communicates with another router/moder wireless through access points.
The communication between my PC and Router its OK and Wirelless.
When i use a cable connection between my pc and the router the routing its ok and all packets are being redirected to the router/modem (from IPs 192.168.100.1 to 192.168.0.1 actually i can browse to the internet...)
The BVI Interface Has the IP 192.168.100.1
The FastEthernet 0 Interface has been set to Trunk Mode. (Here is plugged the Access Point...)
Interface VLAN1 is configured 'for routing'...
So, when i connect through wireless card to the router i can see it but i can not see anything else. Its supposed that the router should redirect me to 192.168.0.1 Subnet...
The physical status is :
PC->Wirelless PCI Card -> Router 876 -> AccessPoint -> ...wirelless.. ->Access Point -> Modem/Router->Internet
The config from router is :
bridge irb
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no cdp enable
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport mode trunk
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Dot11Radio0
no ip address
ip virtual-reassembly
encryption mode wep mandatory
ssid OFFICENET
vlan 1
authentication open
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip nat allow-static-host
bridge-group 1
interface BVI1
description $ES_LAN$
ip address 192.168.100.1 255.255.255.0
ip nat inside
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
logging trap debugging
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
k.poplitz
Level 7
Level 7
Check if the native VLAN configuration on the Switch port to which the AP is connected to matches with that of the AP's native VLAN.
