9120 AP logs
Moudar
I got a customer who is complaining about the connection (they are losing connection every here and then)
The AP is  C9120AXI. What i could see is a lot of weird logs:
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.3688] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.3788] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.3888] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.3898] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.3998] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4098] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4198] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4298] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4398] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4508] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4608] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4708] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4808] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.4918] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5018] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5118] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5218] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5328] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5428] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5528] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5628] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5728] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5828] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.5938] write_offchan: off-chan message dropped
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.6038] write_offchan: off-chan message droppe
May  8 12:42:06 kernel: [*05/08/2023 12:42:06.9958] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [05/08/2023 12:42:07.0018] NXP-RHL-Driver 0001:01:00.0: rhbwifi_sysfs_get_cal_ptr: offset[6fa0], size[12240]
May  8 12:42:07 kernel:  SUBSYSTEM=pci
May  8 12:42:07 kernel:  DEVICE=+pci:0001:01:00.0
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0058] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0168] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0268] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0368] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0468] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0568] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0678] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0778] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.0878] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [05/08/2023 12:42:07.1038] NXP-RHL-Driver 0001:01:00.0: rhbwifi_sysfs_get_cal_ptr: offset[9f70], size[12240]
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1038] write_offchan: off-chan message dropped
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1058] EEPROM Size = 65536
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1058] loading trx table from EEPROM to DTCM
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1058] 24480 bytes copied from RHL EEPROM to DTCM
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1058] loading ro1 table from EEPROM to DTCM
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1058] 12240 bytes copied from RHL EEPROM to DTCM
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1058] loading ro2 table from EEPROM to DTCM
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1268] systemd[1]: Starting Sensord daemon...
May  8 12:42:07 kernel: [*05/08/2023 12:42:07.1688] systemd[1]: Started Sensord daemon.
May  8 12:42:28 eeprom_api[30602]: FW: SAgE phys_buff=0xA2600000 / 3ffac00
May  8 12:42:28 eeprom_api[30602]: FW: SAgE virt_buff=0x7fa9803000
May  8 12:42:28 eeprom_api[30602]: System page_size=4096, mask=FFFFFFFFFFFFF000
May  8 12:42:28 eeprom_api[30602]: Closing dummy socket
May  8 12:42:28 eeprom_api[30602]: read 0 bytes from eeprom: 6 0 f 1
May  8 12:42:28 eeprom_api[30602]: read 0 bytes from eeprom: ffffffff 4 18 ffffffff
May  8 12:42:28 eeprom_api[30602]: read 0 bytes from eeprom: 2e 13 1e 28
May  8 12:42:28 eeprom_api[30602]: I_SKU: Hardware ID = C401
May  8 12:43:30 NCI: I0: openSensor(slot=0)
May  8 12:43:30 eeprom_api[30602]: cfg loopback only mode 0
May  8 12:43:31 NCI: I0: SensorApp=f64b4d40
May  8 12:43:31 NCI: I0: SensorHdw=1.5.3
May  8 12:43:31 NCI: I0: Hardware Radio Band = [4890, 5935] MHz, BW=75313
May  8 12:43:31 NCI: I0: Hardware Radio Band = [2400, 2500] MHz, BW=75313
May  8 12:43:31 NCI: slot=0 mode=1 chanCnt=29 cw=255
May  8 12:43:31 NCI: chans: 1 2 3 4 5 6 7 8 9 10 11
May  8 12:43:31 NCI:        12 13 36 40 44 48 52 56 60 64 100
May  8 12:43:31 NCI:        104 108 112 116 132 136 140 0 0 0 0
May  8 12:43:31 NCI: I0: channel map channels: in=29 cloned=29
May  8 12:43:31 NCI: I0: Requesting MonBand [2400, 2492] bw=0MHz/0 ant=0xbc
May  8 12:43:31 NCI: I0: Monitoring (cf=2446, span=92), RadioUsage=5%
May  8 12:43:31 NCI: I0:     dwell=25000us, update=3000ms, resBW=156251
May  8 12:43:31 NCI: I0: Requesting MonBand [5160, 5340] bw=0MHz/0 ant=0xbc
May  8 12:43:31 NCI: I0: Monitoring (cf=5250, span=180), RadioUsage=6%
May  8 12:43:31 NCI: I0:     dwell=20000us, update=3000ms, resBW=156250
May  8 12:43:31 NCI: I0: Requesting MonBand [5480, 5720] bw=0MHz/0 ant=0xbc
May  8 12:43:31 NCI: I0: Monitoring (cf=5600, span=240), RadioUsage=8%
May  8 12:43:31 NCI: CLEANAIR: Slot 0 enabled
May  8 12:43:31 NCI: IPC sent -1/28, /tmp/mrvlfwd_ipc, type=6, retries 0, Broken pipe
May  8 12:43:32 eeprom_api[30602]: DART Antenna is not supported
Any idea what are these logs mean?
The customer said that the AP was blinking red and blue for some minutes! Why should it do this?
WLC 5520 runing 8.10.181.3
19 Replies 19
Checking the switch port logging shows that the port gone up/down many times!
No ,clear reason why. I will go there and check the environment to see if it is heat reason to this CAPWAP restarting
Moudar
Here are some new logs from the same AP. I will check it in place tomorrow
May 16 13:04:27 kernel: [*05/16/2023 13:04:27.0923] set cleanair [slot0][band0] enabled
May 16 13:04:27 kernel: [*05/16/2023 13:04:27.0943] set cleanair [slot0][band1] enabled
May 16 13:04:27 kernel: [*05/16/2023 13:04:27.0983] set cleanair [slot1][band1] enabled
May 16 13:04:27 NCI: I0: openSensor(slot=0)
May 16 13:04:27 eeprom_api[6482]: cfg loopback only mode 0
May 16 13:04:28 NCI: I0: SensorApp=f64b4d40
May 16 13:04:28 NCI: I0: SensorHdw=1.5.3
May 16 13:04:28 NCI: I0: Hardware Radio Band = [4890, 5935] MHz, BW=75313
May 16 13:04:28 NCI: I0: Hardware Radio Band = [2400, 2500] MHz, BW=75313
May 16 13:04:28 NCI: slot=0 mode=1 chanCnt=29 cw=255
May 16 13:04:28 NCI: chans: 1 2 3 4 5 6 7 8 9 10 11
May 16 13:04:28 NCI:        12 13 36 40 44 48 52 56 60 64 100
May 16 13:04:28 NCI:        104 108 112 116 132 136 140 0 0 0 0
May 16 13:04:28 NCI: I0: channel map channels: in=29 cloned=29
May 16 13:04:28 NCI: I0: Requesting MonBand [2400, 2492] bw=0MHz/0 ant=0xbc
May 16 13:04:28 NCI: I0: Monitoring (cf=2446, span=92), RadioUsage=5%
May 16 13:04:28 NCI: I0:     dwell=25000us, update=3000ms, resBW=156251
May 16 13:04:28 NCI: I0: Requesting MonBand [5160, 5340] bw=0MHz/0 ant=0xbc
May 16 13:04:28 NCI: I0: Monitoring (cf=5250, span=180), RadioUsage=6%
May 16 13:04:28 NCI: I0:     dwell=20000us, update=3000ms, resBW=156250
May 16 13:04:28 NCI: I0: Requesting MonBand [5480, 5720] bw=0MHz/0 ant=0xbc
May 16 13:04:28 NCI: I0: Monitoring (cf=5600, span=240), RadioUsage=8%
May 16 13:04:28 NCI: CLEANAIR: Slot 0 enabled
May 16 13:04:31 NCI: CLEANAIR: Slot 1 channel change chk
can it be a problem with cleanair?
CSCwd21996
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwd21996
There are some recent bugs with the cleanair process failing - if you want those fixed then update the software.
However that won't explain the problem you're reporting - it just leaves cleanair in a down state on the AP.
today i changed that AP to a new one same model. What i am getting of logs is like this:
May 17 08:53:34 kernel: [*05/17/2023 08:53:34.8122] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet 68:D9:3C:CA:ED:23
May 17 08:53:34 kernel: [*05/17/2023 08:53:34.8122] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet 1C:FC:17:6F:ED:EA
May 17 08:55:46 kernel: [*05/17/2023 08:55:46.5728] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet F6:1F:EA:4F:EC:4B
May 17 09:04:27 kernel: [*05/17/2023 09:04:27.7432] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet F6:1F:EA:4F:EC:4B
May 17 09:07:58 kernel: [*05/17/2023 09:07:58.7522] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet F6:1F:EA:4F:EC:4B
May 17 09:10:32 kernel: [*05/17/2023 09:10:32.5622] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet 24:1B:7A:AC:4D:77
May 17 09:10:32 kernel: [*05/17/2023 09:10:32.6742] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet 24:1B:7A:AC:4D:77
May 17 09:10:42 kernel: [*05/17/2023 09:10:42.5302] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet 24:1B:7A:AC:4D:77
May 17 09:11:01 kernel: [*05/17/2023 09:11:01.7491] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet F6:1F:EA:4F:EC:4B
May 17 09:14:54 kernel: [*05/17/2023 09:14:54.1341] chatter: client_ip_table :: ClientIPTable no client entry found, dropping packet C4:18:E9:0B:7C:21
I still not getting calls that complain. What are these logs about? Sure these MAC addresses belong to clients being dropped!
I have same probelem in 9120AX AP's however i am running with latest IOS 17.6.X in WLC
wwmnshew09c91#sh logging
Console logging : Level - notification, Status - enabled
Syslog logging : Level - information, Status - active, IP - 255.255.255.255
System logging :
May 24 01:06:07 kernel: [*05/24/2023 01:06:07.9710] write_offchan: off-chan message dropped
May 24 01:06:07 kernel: [*05/24/2023 01:06:07.9810] write_offchan: off-chan message dropped
May 24 01:06:07 kernel: [*05/24/2023 01:06:07.9910] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0010] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0110] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0120] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0220] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0320] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0420] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0520] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0530] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0630] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0730] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0830] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.0930] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1040] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1140] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1240] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1340] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1440] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1540] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1550] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1650] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1750] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1850] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.1950] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2050] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2260] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2360] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2460] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2560] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2660] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2670] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2770] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2870] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.2970] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3070] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3170] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3230] EEPROM Size = 65536
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3230] loading pow table from EEPROM to scratch buf
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3230] 10200 bytes copied from RHL EEPROM to scratch buf
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3280] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3380] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3480] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3580] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3680] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3790] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3890] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.3990] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4100] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4200] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4300] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4410] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4510] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4610] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4710] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4810] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4910] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.4920] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5020] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5120] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5220] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5320] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5420] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5430] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5530] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5630] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5730] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5830] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.5940] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6040] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6140] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6240] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6340] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6680] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6780] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6880] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6980] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.6990] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7090] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7190] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7290] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7390] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7490] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7600] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7700] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7800] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.7900] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8000] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8100] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8110] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8210] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8310] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8410] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8510] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8610] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8720] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8820] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.8920] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9020] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9120] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9130] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9230] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9330] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9430] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9530] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9640] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9740] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9840] write_offchan: off-chan message dropped
May 24 01:06:08 kernel: [*05/24/2023 01:06:08.9940] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0040] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0140] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0150] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0250] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0350] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0450] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0550] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0650] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.0950] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1050] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1150] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1250] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1350] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1360] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1460] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1560] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1660] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1760] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1860] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1870] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.1970] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2070] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2170] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2270] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2380] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2480] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2580] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2680] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2780] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2890] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.2990] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3090] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3190] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3300] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3400] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3500] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3600] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3710] write_offchan: off-chan message dropped
May 24 01:06:09 kernel: [*05/24/2023 01:06:09.3810] write_offchan: off-chan message dropped
