9800-40 HA pair, Active unit always in alarm state
David Ritter
Level 4
Level 4
My c9800-40 pair always shows and Red(Amber) Alarm led on the active unit.  At first I thought it was the stand-by unit but no it be the active unit and toggles between boxes if I trip failover.
There is no such behavior documented .  Documentation would suggest Alarm led sould be stdy green and the HA led green (for hot)
Any idea's.
Rasika Nayanajith
Does below CLI provide any output
WLC#show facility-alarm status
Rasika
Rasika Nayanajith
Rasika
LOL
System Totals Critical: 3 Major: 0 Minor: 0
Source Time
Severity Description [Index]
xcvr container 0/0/1 Nov 20 2020 09:45:33 CRITICAL
Transceiver Missing - Link Down [1]
xcvr container 0/0/2 Nov 20 2020 09:45:33 CRITICAL
xcvr container 0/0/3 Nov 20 2020 09:45:33 CRITICAL
Um I only configured 1 port.. why would it complain about the empty,
configured ports
ok, I just placed the 3 in shut status..
myWLC#show facility-alarm status
System Totals Critical: 0 Major: 0 Minor: 0
Source Time
xcvr container 0/0/1 Nov 30 2020 12:37:35 INFO
Transceiver Missing [0]
xcvr container 0/0/2 Nov 30 2020 12:37:45 INFO
xcvr container 0/0/3 Nov 30 2020 12:37:53 INFO
guess that turned off the led..
Thank you Riska
Good to hear that David...
