Open and Enhanced Open on same WLAN
DJX995
Level 3
Level 3
Is it possible to have both Open and Enhanced open (OWE) on the same WLAN?
Like how you can enable WPA2 and WPA3 on a WLAN, I would like to enable OWE and still support older clients that don't support WPA3 OWE.
Thanks!
2 Accepted Solutions
This is the CLI equivalent of mapping those SSID, listed on the same URL
  • config wlan security owe-tm enable owe-wlan-id open-wlan-id
  • config wlan security owe-tm enable open-wlan-id owe-wlan-id
Rasika
6 Replies 6
Rasika Nayanajith
No, it is not possible.
Enhanced Open Transition mode designed to work with two SSID, one with broadcast (open) & other with hidden (OWE), then they linked to each other to give smoother user experience.
See below post
https://mrncciew.com/2019/11/22/enhanced-open-part-2/
Rasika
*** Pls rate all useful responses ***
That's what I would like to implement.
There they did it via the GUI.
Are there any links you could provide for doing this via the CLI?
Thanks!
Here is the CLI config options in AireOS
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/wlan_security.html#config-enhanced-open-cli
Assume you do it in AireOS based WLC
Rasika
Thanks.
I saw that but it doesn't specifically say anything about the "transition" technology or how to link the regular open SSID to the new OWE SSID.
Rasika
Thanks.
I'll give this a try soon.
