9800-40: Problem creating management trustpoint, missed zeroday
Eric Hansen
Got a pair of brand new 9800-40's running 16.12.01s.  At the time I set them up I didn't have the LAG ports cabled, just the g0 management.  So *i thinnk* when the zero day script ran the ap management trustpoint didn't get created right.
I now have the 9800-40 up and running and I am trying to get the ap management trustpoint created by running 'wireless config vwlc-ssc' command in cli..... but it appears that the script never creates the self signed cert, or never assigns it to the trustpoint correctly.
Does anyone know of a way around this?
Instruction_showing_trustpoint_script.jpgtrustpoint_script_not_running.jpg Thanks
Eric-
Eric Hansen
Solution for anyone who happens to have this same problem.
Apparently you *can not* create the management interface in the GUI and then run the 'wireless config vwlc-ssc' in the CLI.  Why?  Who knows.  If you create the management interface in the GUI you have to delete it and create both it and the 'wireless config vwlc-ssc' command in CLI.
