9800 Licensing
lcaruso
Level 10
Level 10
Trying to get a parts list together for a 9800 purchase. Account team is not getting back to us on these questions:
Do we need two DTLS licenses with 9800-40 SSO configuration?
Do the 9800s need DNA licenses as do the APs?
Thanks in advance.
17 Replies 17
The WLC needs to have AP license.
Rich R
So for AP registration on 9800 , Do we require any license or not ? YES
If yes which one . We have mix of 2700 APs and 9100 series? The licenses are not model specific they are feature specific.  All APs on the WLC must have the same feature level licenses.  There are 2 levels - Essentials and Advantage.  You buy them as term licenses although the network part is perpetual (remains valid even after the DNA term expires).
https://www.cisco.com/c/m/en_us/products/software/dna-subscription-wireless/en-sw-sub-matrix-wireless.html
https://www.cisco.com/c/en/us/products/collateral/software/one-wireless-subscription/nb-06-dna-sw-sub-wl-data-sheet-ctp-en.html
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/guide-c07-742134.html
So you select AIR-DNA-A or AIR-DNA-E and then the term of the subscription you want to buy.  The licenses are deposited in your smart licensing account then the WLC fetches them on-demand as APs join.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
