9800 RRM TPC with or without antenna gain?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-30-2024 07:55 AM
i have an Ekahau Site Survey 9120AXI APs with transmit power 9 dBm (EIRP 14 dBi) on 5 GHz band, what is the equivalent setting on 9800 WLC in RRM / TPC max level?
do i set on the WLC RRM/TPC 14 dBm and antenna gain 10 x 0.5,
or do i set on the WLC RRM/TPC 9 dBm and antenna gain 10 x 0.5 dBi
- Labels:
Catalyst Wireless Controllers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-30-2024 10:07 AM
- Note that when using default settings the 9800 will auto regulate RRM TPC (and Dynamic Channel Assignment (DCA)) , based on neighboring APs and making sufficient cell coverage ,
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-18-2024 11:12 AM - edited 09-18-2024 11:13 AM
Hi @merilcerpos , how are you?
I have the exact same doubt. Although I had opened one or more related TAC cases to discuss this, and the final answer I had was:
The value configured on TPC (Max and Min) both relate to EIRP values, then it should be final power: TX Power + Antenna Gain.
But I still have some doubts and uncertainties about this matter. Did you get this cleared somehow?
Thanks.
