9800 Wireless Controller Device Classification Failed
Kagamigawa
The 9800 wireless controller failed to classify devices, causing the wireless air interface scheduling optimization to fail.
9800CL#show install summary
[ Chassis 1/R0 ] Installed Package(s) Information:
State (St): I - Inactive, U - Activated & Uncommitted,
            C - Activated & Committed, D - Deactivated & Uncommitted
Type  St   Filename/Version
IMG   C    17.15.04d.0.311
APSP   C    bootflash:C9800-CL-universalk9.17.15.04d.CSCws82234.SPA.apsp.bin
Auto abort timer: inactive
9800CL#
9800CL#show wlan name Chloe_5G
WLAN Profile Name     : Chloe_5G
Identifier                                     : 2
Description                                    :
Network Name (SSID)                            : Chloe_5G
Status                                         : Enabled
Broadcast SSID                                 : Enabled
Advertise-Apname                               : Enabled
Universal AP Admin                             : Disabled
Max Associated Clients per WLAN                : 0
Max Associated Clients per AP per WLAN         : 0
Max Associated Clients per AP Radio per WLAN   : 200
OKC                                            : Enabled
Number of Active Clients                       : 2
CHD per WLAN                                   : Enabled
WMM                                            : Required
WiFi Direct Policy                             : Disabled
Channel Scan Defer Priority:
  Priority (default)                           : 5
  Priority (default)                           : 6
Scan Defer Time (msecs)                        : 100
Media Stream Multicast-direct                  : Disabled
CCX - AironetIe Support                        : Enabled
Peer-to-Peer Blocking Action                   : Disabled
Configured Radio Bands
      5GHz                                     : Enabled
      Slot                                     : Enabled on all slots
Operational State of Radio Bands
      5GHz                                     : UP
DTIM period for 802.11a radio                  : 1
DTIM period for 802.11b radio                  : 1
Local EAP Authentication                       : Disabled
Mac Filter Authorization list name             : Disabled
Mac Filter Override Authorization list name    : Disabled
Accounting list name                           :
802.1x authentication list name                : Disabled
802.1x authorization list name                 : Disabled
Security
    FT Support                                 : Enabled
        FT Reassociation Timeout (secs)        : 20
        FT Over-The-DS mode                    : Disabled
    Web Based Authentication                   : Disabled
    OWE Transition Mode                        : Disabled
    Conditional Web Redirect                   : Disabled
    Splash-Page Web Redirect                   : Disabled
    Webauth On-mac-filter Failure              : Disabled
    Webauth Authentication List Name           : Disabled
    Webauth Authorization List Name            : Disabled
    Webauth Parameter Map                      : Disabled
    Security-2.4GHz/5GHz
         802.11 Authentication                      : Open System
         Static WEP Keys                            : Disabled
         Wi-Fi Protected Access (WPA/WPA2/WPA3)     : Enabled
             WPA (SSN IE)                           : Disabled
             WPA2 (RSN IE)                          : Disabled
             WPA3 (WPA3 IE)                         : Enabled
                 AES Cipher                         : Enabled
                 CCMP256 Cipher                     : Disabled
                 GCMP128 Cipher                     : Disabled
                 GCMP256 Cipher                     : Enabled
             Auth Key Management
                 802.1x                             : Disabled
                 PSK                                : Disabled
                 CCKM                               : Disabled
                 FT dot1x                           : Disabled
                 FT PSK                             : Disabled
                 FT SAE                             : Enabled
                 FT SAE-EXT-KEY                     : Enabled
                 Dot1x-SHA256                       : Disabled
                 PSK-SHA256                         : Disabled
                 SAE                                : Enabled
                 OWE                                : Disabled
                 SUITEB-1X                          : Disabled
                 SUITEB192-1X                       : Disabled
         SAE PWE Method                             : Hash to Element, Hunting and Pecking(H2E-HNP)
         Transition Disable                         : Disabled
         CCKM TSF Tolerance (msecs)                 : 1000
         OSEN                                       : Disabled
         PMF Support                                : Required
             PMF Association Comeback Timeout (secs): 1
             PMF SA Query Time (msecs)              : 200
         Beacon Protection                          : Disabled
     Security-6GHz
             Auth Key Management
                 FT dot1x                           : Disabled
                 FT SAE                             : Enabled
                 SAE                                : Enabled
                 OWE                                : Disabled
         SAE PWE Method                             : Hash to Element(H2E)
Band Select                                    : Disabled
Load Balancing                                 : Disabled
Multicast Buffer                               : Disabled
Multicast Buffers (frames)                     : 0
IP Source Guard                                : Disabled
Assisted-Roaming
    Neighbor List                              : Enabled
    Prediction List                            : Enabled
    Dual Band Support                          : Disabled
IEEE 802.11v parameters
    Directed Multicast Service                 : Disabled
    BSS Max Idle                               : Enabled
        Protected Mode                         : Disabled
    Traffic Filtering Service                  : Disabled
    BSS Transition                             : Enabled
        Disassociation Imminent                : Disabled
            Optimised Roaming Timer (TBTTS)    : 40
            Timer (TBTTS)                      : 200
        Dual Neighbor List                     : Enabled
    WNM Sleep Mode                             : Disabled
802.11ac MU-MIMO                               : Enabled
802.11ax parameters
    802.11ax Operation Status                  : Enabled
    OFDMA Downlink                             : Enabled
    OFDMA Uplink                               : Enabled
    MU-MIMO Downlink                           : Enabled
    MU-MIMO Uplink                             : Enabled
    BSS Target Wake Up Time                    : Enabled
    BSS Target Wake Up Time Broadcast Support  : Disabled
802.11be profile name                          : default-dot11be-profile
802.11 protocols in 2.4GHz band
    Protocol                                   : dot11bg
Advanced Scheduling Requests Handling          : Enabled
mDNS Gateway Status                            : Bridge
WIFI Alliance Agile Multiband                  : Disabled
Device Analytics
    Advertise Support                          : Enabled
    Advertise Support for PC analytics         : Enabled
    Share Data with Client                     : Enabled
Client Scan Report (11k Beacon Radio Measurement)
    Request on Association                     : Enabled
    Request on Roam                            : Enabled
WiFi to Cellular Steering                      : Disabled
6Ghz Client Steering                           : Disabled
Locally Administered Address Configuration
    Deny LAA clients                           : Disabled
Latency Measurements Announcements             : Disabled
Client geolocation
    FTM responder                              : Disabled
    Advertise AP location                      : Disabled
9800CL#
Client MAC Address : f481.c483.02f9
Client MAC Type : Universally Administered Address
Client DUID: NA
Client IPv4 Address : 192.168.31.71
Client IPv6 Addresses : fe80::1451:2243:cceb:d475
                        240e:348:562:14a1:50bd:3d79:33c4:bb41
                        240e:348:562:14a1:ceb:3a0c:6c4:57d5
Client Username: N/A
AP MAC Address : 087b.87ff.8540
AP Name: bedroom
AP slot : 1
Client State : Associated
Policy Profile : default-policy-profile
Flex Profile : default-flex-profile
Wireless LAN Id: 2
WLAN Profile Name: Chloe_5G
Wireless LAN Network Name (SSID): Chloe_5G
BSSID : 087b.87ff.854e
Connected For : 15804 seconds
Protocol : 802.11ax - 5 GHz
Channel : 161
Client IIF-ID : 0xa0000017
Association Id : 33
Authentication Algorithm : Open System
Idle state timeout : N/A
Session Timeout : 28800 sec (Remaining time: 12996 sec)
Session Warning Time : Timer not running
Input Policy Name  : None
Input Policy State : None
Input Policy Source : None
Output Policy Name  : None
Output Policy State : None
Output Policy Source : None
WMM Support : Enabled
U-APSD Support : Disabled
Fastlane Support : Disabled
Client Active State : Active
Power Save : ON
Current Rate : m11 ss2
Supported Rates : 54.0
AAA QoS Rate Limit Parameters:
  QoS Average Data Rate Upstream             :  (kbps)
  QoS Realtime Average Data Rate Upstream    :  (kbps)
  QoS Burst Data Rate Upstream               :  (kbps)
  QoS Realtime Burst Data Rate Upstream      :  (kbps)
  QoS Average Data Rate Downstream           :  (kbps)
  QoS Realtime Average Data Rate Downstream  :  (kbps)
  QoS Burst Data Rate Downstream             :  (kbps)
  QoS Realtime Burst Data Rate Downstream    :  (kbps)
Mobility:
  Move Count                  : 0
  Mobility Role               : Local
  Mobility Roam Type          : None
  Mobility Complete Timestamp : 01/30/2026 05:43:56 CST
Client Join Time:
  Join Time Of Client : 01/30/2026 05:43:56 CST
Client State Servers : None
Client ACLs : None
Policy Manager State: Run
Last Policy Manager State : IP Learn Complete
Client Entry Create Time : 15804 seconds
Policy Type : WPA3
Encryption Cipher : GCMP256
Authentication Key Management : FT-SAE
AAA override passphrase : No
Transition Disable Bitmap : None
Beacon Protection : No
User Defined (Private) Network : Disabled
User Defined (Private) Network Drop Unicast : Disabled
Encrypted Traffic Analytics : No
Protected Management Frame - 802.11w : Yes
EAP Type : Not Applicable
VLAN Override after Webauth : No
VLAN : default
Multicast VLAN : 0
VRF Name : N/A
WiFi Direct Capabilities:
  WiFi Direct Capable           : No
Central NAT : DISABLED
Session Manager:
  Point of Attachment : capwap_90000008
  IIF ID             : 0x90000008
  Authorized         : TRUE
  Session timeout    : 28800
  Common Session ID: 00000000000002190BB5A2BA
  Acct Session ID  : 0x00000000
  Auth Method Status List
  	Method : FT-SAE
  Local Policies:
  	Service Template : wlan_svc_default-policy-profile (priority 254)
  		VLAN             : 1
  		Absolute-Timer   : 28800
  Server Policies:
  Resultant Policies:
  		VLAN Name        : default
  		VLAN             : 1
DNS Snooped IPv4 Addresses : None
DNS Snooped IPv6 Addresses : None
Client Capabilities
  CF Pollable : Not implemented
  CF Poll Request : Not implemented
  Short Preamble : Not implemented
  PBCC : Not implemented
  Channel Agility : Not implemented
  Listen Interval : 0
Fast BSS Transition Details :
  Reassociation Timeout : 20
11v BSS Transition : Implemented
11v DMS Capable : No
QoS Map Capable : No
FlexConnect Data Switching : Local
FlexConnect Dhcp Status : Local
FlexConnect Authentication : Local
Client Statistics:
  Number of Bytes Received from Client : 8583306
  Number of Bytes Sent to Client : 12069343
  Number of Packets Received from Client : 39567
  Number of Packets Sent to Client : 29985
  Number of Data Retries : 903
  Number of RTS Retries : 0
  Number of Tx Total Dropped Packets : 0
  Number of Duplicate Received Packets : 0
  Number of Decrypt Failed Packets : 0
  Number of Mic Failured Packets : 0
  Number of Mic Missing Packets : 0
  Number of Policy Errors : 0
  Radio Signal Strength Indicator : -26 dBm
  Signal to Noise Ratio : 71 dB
  Last statistics update : 01/30/2026 10:05:52
  Number of links dropped due to downsizing : 0
  Client Statistics per band:
    Radio Band 5GHz
      AP slot : 1
Fabric status : Disabled
Radio Measurement Enabled Capabilities
  Capabilities: None
Client Scan Report Time : Timer not running
Client Scan Reports
Assisted Roaming Neighbor List
Nearby AP Statistics:
EoGRE : Pending Classification
Device Classification Information:
  Device Type      : Apple-iPad
  Device Name      : iPad
  Protocol Map     : 0x000029  (OUI, DHCP, HTTP)
  Device Protocol  : HTTP
    Type             : 1    24
    Data             : 18
    00000000  00 01 00 14 63 6f 6d 2e  61 70 70 6c 65 2e 74 72  |....com.apple.tr|
    00000010  75 73 74 64 2f 33 2e 30                            |ustd/3.0        |
Max Client Protocol Capability:
WiFi to Cellular Steering : Not implemented
Cellular Capability : N/A
Advanced Scheduling Requests Details:
  Apple Specific Requests(ASR) Capabilities/Statistics:
    Regular ASR support: ENABLED
    Non-default Fastlane Profile: Not Active
    Range            Voice             Video            Background              Best-Effort
    [0-20ms]         129                0                54                    515
    [20-40ms]           0                0                 0                      0
    [40-100ms]           0                0                 0                      0
    [>100ms]           0                0                 0                      0
L3 Access : DISABLED
compare ipad Air M3 & iphone 17 pro
Client MAC Address : 5c13.cc10.5f66
Client DUID: NA
Client IPv4 Address : 192.168.31.76
Client IPv6 Addresses : 240e:348:751:26d1:80ed:ae96:36c:add3
                        fe80::40e:f23b:7470:192f
AP Name: bedroom
AP slot : 1
Wireless LAN Id: 2
Connected For : 3054 seconds
Channel : 64
Client IIF-ID : 0xa0000018
Association Id : 1
Session Timeout : 28800 sec (Remaining time: 25746 sec)
Power Save : ON
Mobility:
  Move Count                  : 0
  Mobility Complete Timestamp : 01/17/2026 09:33:40 CST
Client Join Time:
  Join Time Of Client : 01/17/2026 09:33:40 CST
Client ACLs : None
Client Entry Create Time : 10396 seconds
Policy Type : WPA2
Encryption Cipher : CCMP (AES)
Authentication Key Management : FT-PSK
Protected Management Frame - 802.11w : No
VLAN : default
Multicast VLAN : 0
VRF Name : N/A
Session Manager:
  Point of Attachment : capwap_90000009
  IIF ID             : 0x90000009
  Authorized         : TRUE
  Common Session ID: 000000000000012CC995C6AB
  	Method : None
  Local Policies:
  		VLAN             : 1
  Server Policies:
  Resultant Policies:
  		VLAN Name        : default
  		VLAN             : 1
Client Capabilities
  Listen Interval : 0
Client Statistics:
  Number of Bytes Received from Client : 74828490
  Number of Bytes Sent to Client : 1337851143
  Number of Packets Received from Client : 374462
  Number of Packets Sent to Client : 1124242
  Number of Data Retries : 74446
  Radio Signal Strength Indicator : -32 dBm
  Signal to Noise Ratio : 65 dB
  Capabilities: None
Client Scan Reports
  Last Report @: 01/17/2026 11:35:58
  Device Type      : Un-Classified Device
  Device Name      : iPhone
    Type             : 1    25
    Data             : 19
    00000000  00 01 00 15 4d 69 63 72  6f 4d 65 73 73 65 6e 67  |....MicroMesseng|
    00000010  65 72 20 43 6c 69 65 6e  74                        |er Client       |
    Regular ASR support: DISABLED
How can I resolve the issue of not being able to manually customize device categories on WLC in Flex mode, just http tlv caching and http tlv caching , no ISE
9 Replies 9
Cristian Matei
@Kagamigawa Look here to understand requirements for device classification to work, otherwise classification relies on HTTP/DHCP probes (which seems to be the case from your provide output).
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-18/config-guide/b_wl_17_18_cg/m_device_ecosystem.html
Check following document to ensure you've properly enabled the feature an also to perform investigations:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/222643-configure-verify-and-troubleshoot-intel.html
   Can you be more precise on what exactly is not working and what are you trying to achieve?
Cristian.
The iPhone 17 Pro is classified as an unclassified device on the 9800 wireless controller, resulting in the Apple Specific Requests (ASR) feature being disabled, but the iPad Air M3 works normally.
9800CL#show devic classifier mac-address 5c13.cc10.5f66 detail
Client Mac: 5c13.cc10.5f66
  Device Type: Un-Classified Device
  Confidence Level: 0
  Device Name: iPhone
9800CL#show devic classifier mac-address f481.c483.02f9 det
Client Mac: f481.c483.02f9
  Device Type: Apple-iPad
  Confidence Level: 20
  Device Name: iPad
9800CL#
9800CL#show wireless client mac-address f481.c483.02f9 det
    [0-20ms]         395                0               422                   10904
    [20-40ms]           0                0                 0                      0
    [40-100ms]           0                0                 0                      0
    [>100ms]           0                0                 0                      0
9800CL#show wireless client mac-address 5c13.cc10.5f66 detail
@Kagamigawa From the documents I've shared, did you validate correct configuration on Cisco side? The iPhone 17 family uses a newer Apple proprietary networking chip, N1, there might be some challenges here. On the second document, there is a troubleshooting / debugging process described. Follow it and post the logs here for analysis.
Cristian.
DHCP option 55 has undergone some changes, and it is not the same for the iPhone 17 Pro and Pro Max.
9800CL#show wireless client mac-address 5c13.cc10.5f66 detail !!!!!!!!!!!!!this is iPhone 17 pro!!!!!!!!!!!!!!!
  Device Protocol  : DHCP
    Type             : 12   10
    Data             : 0a
    00000000  00 0c 00 06 69 50 68 6f  6e 65                     |....iPhone      |
    Type             : 55   14
    Data             : 0e
    00000000  00 37 00 0a 01 79 03 06  0f 6c 72 77 a2 fc         |.7...y...lrw..  |
    Type             : 1    24
    Data             : 18
show wireless client mac-address 107d.c8dc.e547 detail  !!!!!!!!!!!!!this is iPhone 17 pro Max!!!!!!!!!!!!!!!
  Device Name      : yuuuuers-iPhone
    Type             : 12   19
    Data             : 13
    00000000  00 0c 00 0f 79 75 75 75  75 65 72 73 2d 69 50 68  |....yuuuuers-iPh|
    00000010  6f 6e 65                                          |one             |
    Type             : 55   14
    Data             : 0e
    Type             : 1    25
    Data             : 19
livingroom#debug client 5c13.cc10.5f66
livingroom#Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8610] [1769872313:861021] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_AUTHENTICATION : (.)
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8618] CLSM[5C:13:CC:10:5F:66]: US Auth(b0) seq 4007 IF 91 slot 1 vap 1 len 43 state DELETE_PENDING
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8622] CLSM[5C:13:CC:10:5F:66]: DS Auth len 43 slot 1 vap 1
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8624] [1769872313:862420] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DOT11_AUTHENTICATION : (.)
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8625] CLSM[5C:13:CC:10:5F:66]: Driver send mgmt frame success Radio 1 Vap 1
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8625] CLSM[5C:13:CC:10:5F:66]: client moved from DELETE_PENDING to AUTH
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8632] [1769872313:863231] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DOT11_AUTHENTICATION : (.) [Tx Success]
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8647] [1769872313:864717] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ASSOC_REQUEST : (.)
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8699] CLSM[5C:13:CC:10:5F:66]: US Assoc Req(0) seq 4008 IF 91 slot 1 vap 1 len 301 state AUTH
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8705] CLSM[5C:13:CC:10:5F:66]: Populate client capability: cap_from_click=true, max_cap_found=5, assoc_cap=5, max_cap=5, ht=true, vht=true, he=true, he6e=false, eht=false
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8708] CLSM[5C:13:CC:10:5F:66]: DS Assoc Resp(10) IF 17 slot 1 vap 1 state AUTH, generated by AP
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8806] [1769872313:880684] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DOT11_ASSOC_RESPONSE : (.)
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8808] CLSM[5C:13:CC:10:5F:66]: Driver send mgmt frame success Radio 1 Vap 1
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8809] CLSM[5C:13:CC:10:5F:66]: client moved from AUTH to ASSOC
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8813] CLSM[5C:13:CC:10:5F:66]: ADD_MOBILE AID 33
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8818] CLSM[5C:13:CC:10:5F:66]: Driver Add Client success AID 33 Radio 1 Vap 1 Enc 15
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8823] CLSM[5C:13:CC:10:5F:66]: Added to ClientIPTable on apr1v1
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8826] CLSM[5C:13:CC:10:5F:66]: client moved from ASSOC to 8021X
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8826] CLSM[5C:13:CC:10:5F:66]: Added to WCP client table AID 33 Radio 1 Vap 1 Enc 15
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8840] [1769872313:884024] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DOT11_ASSOC_RESPONSE : (.) [Tx Success]
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.8842] [1769872313:884289] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] EAPOL_KEY.M1 : DescType 0x02 KeyInfo 0x0088
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9216] [1769872313:921602] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] EAPOL_KEY.M2 : DescType 0x02 KeyInfo 0x0108
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9220] [1769872313:922024] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] EAPOL_KEY.M3 : DescType 0x02 KeyInfo 0x13c8
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9299] [1769872313:929949] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] EAPOL_KEY.M4 : DescType 0x02 KeyInfo 0x0308
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9307] CLSM[5C:13:CC:10:5F:66]: WCP_EVENT_CLIENT_AUTHORIZE : Plumbing key info to driver
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9312] CLSM[5C:13:CC:10:5F:66]: Client ADD Encrypt Key success AID 33 Radio 1 Enc 15 Key Len 32 Key idx 0 Key fa 2a
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9316] CLSM[5C:13:CC:10:5F:66]: ADD_MOBILE AID 33
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9318] CLSM[5C:13:CC:10:5F:66]: Skip key programming due to key match
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9328] CLSM[5C:13:CC:10:5F:66]: client moved from 8021X to IPLEARN_PENDING
Jan 31 15:11:53 livingroom kernel: [*01/31/2026 23:11:53.9331] CLSM[5C:13:CC:10:5F:66]: Local auth (Add) on radio 1 Vap 1 reported to WLC
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0037] [1769872314:  3722] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Radio Measurement - Neighbor Report Request
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0043] [1769872314:  4319] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0051] [1769872314:  5137] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DOT11_ACTION : Radio Measurement - Neighbor Report Response
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0061] [1769872314:  6100] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DOT11_ACTION : Radio Measurement - Neighbor Report Response [Tx Success]
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0558] [1769872314: 55791] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NS : Src fe80:0:0:0:1c42:96b3:e2c4:538d Dst fe80:0:0:0:1c42:96b3:e2c4:538d Targ fe80:0:0:0:1c42:96b3:e2c4:538d
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0566] [1769872314: 56644] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.254
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0567] chatter: ethertype_cl1: 1769872314.056657087: arp who-has 192.168.31.254 tell 192.168.31.64
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0577] [1769872314: 57744] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DHCP_REQUEST : TransId 0x65f58292
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0577] [1769872314: 57784] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_RS : Src ff02:0:0:0:0:0:0:2 Dst ff02:0:0:0:0:0:0:2
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0580] chatter: dhcp_req_local_sw_nonat: 1769872314.057765150: 0.0.0.0.68 > 255.255.255.255.67: udp 308
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0581] [1769872314: 58180] [livingroom] [5c:13:cc:10:5f:66] < wired0> [U:E] DHCP_REQUEST : TransId 0x65f58292
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0583] chatter: dhcp_reply_nonat: 1769872314.057765150: 0.0.0.0.68 > 255.255.255.255.67: udp 308
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0585] chatter: fromdevs_arp_resp: arp reply 192.168.31.254 is-at AC:7A:56:D1:D2:F4
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0587] [1769872314: 58702] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ARP_REPLY : Sender 192.168.31.254 HwAddr ac:7a:56:d1:d2:f4
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0594] CLSM[5C:13:CC:10:5F:66]: client moved from IPLEARN_PENDING to FWD
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0595] [1769872314: 59570] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Request, TID: 6
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0600] [1769872314: 60078] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 6
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0608] chatter: dhcp_from_inet: 1769872314.060234867: 192.168.31.254.67 > 192.168.31.64.68: udp 308
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0610] [1769872314: 61050] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DHCP_ACK : TransId 0x65f58292
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0625] [1769872314: 62488] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DOT11_ACTION : Block Ack - ADDBA Response, TID: 6 [Tx Success]
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0641] [1769872314: 64181] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 6
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0706] [1769872314: 70597] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.64
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.0711] [1769872314: 71130] [livingroom] [5c:13:cc:10:5f:66] < wired0> [U:E] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.64
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.1007] [1769872314:100742] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Vendor specific(127) - Unknown(126)
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.1396] [1769872314:139653] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.254
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.1414] [1769872314:141435] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ARP_REPLY : Sender 192.168.31.254 HwAddr ac:7a:56:d1:d2:f4
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2390] [1769872314:239072] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Request, TID: 0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2393] [1769872314:239371] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2404] [1769872314:240483] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DOT11_ACTION : Block Ack - ADDBA Response, TID: 0 [Tx Success]
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2798] [1769872314:279822] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 4
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2861] [1769872314:286149] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMP_ECHO : Id 9581 Seq 0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2882] [1769872314:288255] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMP_ECHO_REPLY : Id 9581 Seq 0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.2944] [1769872314:294400] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 3
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3310] [1769872314:331077] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.52
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3311] chatter: ethertype_cl1: 1769872314.331100987: arp who-has 192.168.31.52 tell 192.168.31.64
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3326] chatter: fromdevs_arp_resp: arp reply 192.168.31.52 is-at 00:09:B0:60:A0:F0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3327] [1769872314:332760] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ARP_REPLY : Sender 192.168.31.52 HwAddr 00:09:b0:60:a0:f0
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3660] [1769872314:366063] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Request, TID: 2
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3664] [1769872314:366453] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 2
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.3673] [1769872314:367345] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DOT11_ACTION : Block Ack - ADDBA Response, TID: 2 [Tx Success]
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.4439] [1769872314:443952] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] EAPOL_KEY.M1 : DescType 0x02 KeyInfo 0x0088 [Tx Success]
Jan 31 15:11:54 livingroom kernel: [*01/31/2026 23:11:54.4439] [1769872314:443985] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] EAPOL_KEY.M3 : DescType 0x02 KeyInfo 0x13c8 [Tx Success]
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.0768] [1769872315: 76859] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.254
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.0769] chatter: ethertype_cl1: 1769872315.076878966: arp who-has 192.168.31.254 tell 192.168.31.64
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.0779] chatter: fromdevs_arp_resp: arp reply 192.168.31.254 is-at AC:7A:56:D1:D2:F4
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.0780] [1769872315: 78066] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ARP_REPLY : Sender 192.168.31.254 HwAddr ac:7a:56:d1:d2:f4
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.3960] [1769872315:396039] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.64
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.3961] [1769872315:396118] [livingroom] [5c:13:cc:10:5f:66] < wired0> [U:E] ARP_QUERY : Sender 192.168.31.64 TargIp 192.168.31.64
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.3961] chatter: ethertype_cl1: 1769872315.396060373: arp who-has 192.168.31.64 tell 192.168.31.64
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.4839] [1769872315:483980] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] DHCP_ACK : TransId 0x65f58292 [Tx Success]
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.4840] [1769872315:484006] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ARP_REPLY : Sender 192.168.31.254 HwAddr ac:7a:56:d1:d2:f4 [Tx Success]
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.4840] [1769872315:484032] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ARP_REPLY : Sender 192.168.31.254 HwAddr ac:7a:56:d1:d2:f4 [Tx Success]
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.4840] [1769872315:484076] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMP_ECHO_REPLY : Id 9581 Seq 0 [Tx Success]
Jan 31 15:11:55 livingroom kernel: [*01/31/2026 23:11:55.4840] [1769872315:484093] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ARP_REPLY : Sender 192.168.31.52 HwAddr 00:09:b0:60:a0:f0 [Tx Success]
Jan 31 15:11:56 livingroom kernel: [*01/31/2026 23:11:56.5240] [1769872316:523993] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ARP_REPLY : Sender 192.168.31.254 HwAddr ac:7a:56:d1:d2:f4 [Tx Success]
Jan 31 15:11:58 livingroom kernel: [*01/31/2026 23:11:58.8620] [1769872318:862024] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_RS : Src ff02:0:0:0:0:0:0:2 Dst ff02:0:0:0:0:0:0:2
Jan 31 15:11:58 livingroom kernel: [*01/31/2026 23:11:58.8676] [1769872318:867677] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NS : Src 240e:348:563:1471:c:3da7:f995:4d16 Dst 240e:348:563:1471:c:3da7:f995:4d16 Targ 240e:348:563:1471:c:3da7:f995:4d16
Jan 31 15:11:58 livingroom kernel: [*01/31/2026 23:11:58.8690] [1769872318:868999] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NS : Src 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Dst 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Targ 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd
Jan 31 15:11:58 livingroom kernel: [*01/31/2026 23:11:58.9433] [1769872318:943341] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NA : Src 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Dst 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Targ 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd
Jan 31 15:12:00 livingroom kernel: [*01/31/2026 23:12:00.5856] [1769872320:585644] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NA : Src 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Dst 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Targ 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd
Jan 31 15:12:00 livingroom kernel: [*01/31/2026 23:12:00.7365] [1769872320:736497] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 1
Jan 31 15:12:01 livingroom kernel: [*01/31/2026 23:12:01.7724] [1769872321:772392] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMP_ECHO : Id 9581 Seq 0
Jan 31 15:12:01 livingroom kernel: [*01/31/2026 23:12:01.7747] [1769872321:774694] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMP_ECHO_REPLY : Id 9581 Seq 0
Jan 31 15:12:01 livingroom kernel: [*01/31/2026 23:12:01.8103] [1769872321:810338] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 2
Jan 31 15:12:02 livingroom kernel: [*01/31/2026 23:12:02.7639] [1769872322:763962] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMP_ECHO_REPLY : Id 9581 Seq 0 [Tx Success]
Jan 31 15:12:03 livingroom kernel: [*01/31/2026 23:12:03.9223] [1769872323:922289] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NS : Src fe80:0:0:0:ae7a:56ff:fed1:d2f4 Dst fe80:0:0:0:ae7a:56ff:fed1:d2f4 Targ fe80:0:0:0:ae7a:56ff:fed1:d2f4
Jan 31 15:12:03 livingroom kernel: [*01/31/2026 23:12:03.9249] [1769872323:924898] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMPV6_NA : Src fe80:0:0:0:ae7a:56ff:fed1:d2f4 Dst fe80:0:0:0:ae7a:56ff:fed1:d2f4 Targ fe80:0:0:0:ae7a:56ff:fed1:d2f4
Jan 31 15:12:03 livingroom kernel: [*01/31/2026 23:12:03.9315] [1769872323:931550] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] DOT11_ACTION : Block Ack - ADDBA Response, TID: 5
Jan 31 15:12:04 livingroom kernel: [*01/31/2026 23:12:04.8439] [1769872324:843949] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMPV6_NA : Src fe80:0:0:0:ae7a:56ff:fed1:d2f4 Dst fe80:0:0:0:ae7a:56ff:fed1:d2f4 Targ fe80:0:0:0:ae7a:56ff:fed1:d2f4 [Tx Success]
Jan 31 15:12:05 livingroom kernel: [*01/31/2026 23:12:05.9429] [1769872325:942915] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NS : Src 240e:348:562:14a1:9209:d0ff:fe0e:685f Dst 240e:348:562:14a1:9209:d0ff:fe0e:685f Targ 240e:348:562:14a1:9209:d0ff:fe0e:685f
Jan 31 15:12:05 livingroom kernel: [*01/31/2026 23:12:05.9441] [1769872325:944113] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMPV6_NA : Src 240e:348:562:14a1:9209:d0ff:fe0e:685f Dst 240e:348:562:14a1:9209:d0ff:fe0e:685f Targ 240e:348:562:14a1:9209:d0ff:fe0e:685f
Jan 31 15:12:06 livingroom kernel: [*01/31/2026 23:12:06.9239] [1769872326:923957] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMPV6_NA : Src 240e:348:562:14a1:9209:d0ff:fe0e:685f Dst 240e:348:562:14a1:9209:d0ff:fe0e:685f Targ 240e:348:562:14a1:9209:d0ff:fe0e:685f [Tx Succes
Jan 31 15:12:08 livingroom kernel: [*01/31/2026 23:12:08.9661] [1769872328:966094] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMPV6_NS : Src fe80:0:0:0:1c42:96b3:e2c4:538d Dst fe80:0:0:0:1c42:96b3:e2c4:538d Targ fe80:0:0:0:1c42:96b3:e2c4:538d
Jan 31 15:12:08 livingroom kernel: [*01/31/2026 23:12:08.9715] [1769872328:971543] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NA : Src fe80:0:0:0:1c42:96b3:e2c4:538d Dst fe80:0:0:0:1c42:96b3:e2c4:538d Targ fe80:0:0:0:1c42:96b3:e2c4:538d
Jan 31 15:12:10 livingroom kernel: [*01/31/2026 23:12:10.0439] [1769872330: 43938] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMPV6_NS : Src fe80:0:0:0:1c42:96b3:e2c4:538d Dst fe80:0:0:0:1c42:96b3:e2c4:538d Targ fe80:0:0:0:1c42:96b3:e2c4:538d [Tx Success]
Jan 31 15:12:14 livingroom kernel: [*01/31/2026 23:12:14.3398] [1769872334:339838] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMP_ECHO : Id 9581 Seq 0
Jan 31 15:12:14 livingroom kernel: [*01/31/2026 23:12:14.3422] [1769872334:342207] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMP_ECHO_REPLY : Id 9581 Seq 0
Jan 31 15:12:15 livingroom kernel: [*01/31/2026 23:12:15.2439] [1769872335:243952] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMP_ECHO_REPLY : Id 9581 Seq 0 [Tx Success]
Jan 31 15:12:15 livingroom kernel: [*01/31/2026 23:12:15.2439] [1769872335:243980] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMP_ECHO_REPLY : Id 9581 Seq 0 [Tx Success]
Jan 31 15:12:27 livingroom kernel: [*01/31/2026 23:12:27.1757] [1769872347:175724] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMP_ECHO : Id 9581 Seq 0
Jan 31 15:12:27 livingroom kernel: [*01/31/2026 23:12:27.1785] [1769872347:178552] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMP_ECHO_REPLY : Id 9581 Seq 0
Jan 31 15:12:27 livingroom kernel: [*01/31/2026 23:12:27.7239] [1769872347:723939] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMP_ECHO_REPLY : Id 9581 Seq 0 [Tx Success]
Jan 31 15:12:27 livingroom kernel: [*01/31/2026 23:12:27.7239] [1769872347:723966] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMP_ECHO_REPLY : Id 9581 Seq 0 [Tx Success]
Jan 31 15:12:40 livingroom kernel: [*01/31/2026 23:12:40.6455] [1769872360:645541] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:W] ICMPV6_NS : Src 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Dst 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Targ 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd
Jan 31 15:12:40 livingroom kernel: [*01/31/2026 23:12:40.7406] [1769872360:740665] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [U:W] ICMPV6_NA : Src 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Dst 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Targ 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd
un aJan 31 15:12:41 livingroom kernel: [*01/31/2026 23:12:41.2439] [1769872361:243933] [livingroom] [5c:13:cc:10:5f:66] < apr1v1> [D:A] ICMPV6_NS : Src 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Dst 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd Targ 240e:348:563:1471:e9fd:c1b4:d4d2:e0cd [Tx Succes
livingroom#un all
wcp aid debugging is disabled
driver aid debugging is not supported
All possible debugging has been turned off
livingroom#
@Kagamigawa I suggest open a TAC case. Once and if you find the RCA and WA, kindly post an update here.
Cristian.
pieterh
device classification uses probes that scan information in several types of packets sent by a client
packets from newer types of devices may contain intformation that the controller's OS does not yet recognize
-> wait for a supported release
ISE also investigates the packets and seeks a correlation to classify a device
to my knowledge ISE classification correlates even further than the WLC
-> same goes here for newer device models : you need an update package for ISE
do you use ISE? then i think you need to make the modification in ISE, not the WLC.
last: a device classification also pose a security issue for the device itself!
a hacker can misuse the same information to detect the OS version and more
and with this can adjust it's attack on a specific vulnerability for that model/OS
-> it might happen that vendors take measures so it gets more difficult to classify such a device
(as Cisco has close contact with Apple, i don't think this is the case, but it might happen)
balaji.bandi
Check this bug may help you :
https://bst.cisco.com/bugsearch/bug/CSCwn36115
BB
It's true that this problem is, but it hasn't actually been fixed, at least not on 9800-cloud vm. Trying to use the custom xml template can only display the custom model, but the ASR is still in the disabled state.
Maybe contact TAC or upgrade to version  17.18.X to test; this option is required.
BB
