9800WLC and Vocera Broadcast
k.aumell
I've recently migrated 1 building worth of access points to the new 9800WLC. Everything is working swimmingly, except Vocera Broadcasts, which use multicast. I have this working fine on my old 5508s.
I've tried enabling global multicast under "multicast". I assume I am missing something simple. Does anyone have any experience here?
TIA
Rasika Nayanajith
Did you follow this document, you need to enable Multicast globally on 9800 and it needs to have a unique multicast address assigned (should not be used anywhere else in the network). That multicast group address uses 9800 WLC and its AP. Not related to your end devices/Vocera multicast application group address.
9800 Mgm interface should configure with PIM
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215859-video-stream-on-catalyst-9800-wireless-c.html
Here is another training video of mine that explains the 9800 config model & where multicast configs go.
9800 Config Model - Rockstar Multicast for WLAN Pros
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
comricmi
Did you find a solution for this ever?
